Home > Maintenance & Mods (L322) > Alignment done weekly
Laughing Laughing Laughing Bow down Thumbs Up
Post #224206 21st Nov 2013 12:04am
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I've been charged as much as £200 in Aberdeen for a 4 wheel alignment on a Touareg. Cracking job but typical of local Aberdeen pricing for most things. 4.4 TDV8 Vogue Baltic Blue MY11
Post #224207 21st Nov 2013 12:05am
Dolphinboy
Protyre - 50 quid. make sure whoever does it has the right equipment as it requires special 4 x 4 I believe.
Post #224346 21st Nov 2013 7:27pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Had mine done at a tyre place once for £40 took about 20 minutes and cost me 2 front tyres within about 2 months as it took the outer edge off them both, ended up getting it done at the dealers for £160 and it took 2 hours and recieved a full print out of all the measured angles against the specs.
Post #224838 23rd Nov 2013 9:44pm
birchyman71
Post #224839 23rd Nov 2013 9:44pm
wealy
It's a specialist job.... The guy doing it has to know the exact spec and tolerances of what he needs to achieve. I did it myself once with some borrowed mirrors and equipment.
I thought I had done an accurate job but the tyres were shot within 600 miles as I had set it to the wrong tolerances, which I found out after the tyres wore out.
Gotta know what you are doing.
I had a similar experience with a fast fit garage recently that didn't have my exact model of car in his computer so he went for the nearest that he thought would do!!! Turned out to be miles from where it should be???
If I hadn't have checked it could have cost me a pair of rear tyres Big Cry
The garage paid to have it done at a main dealer and they said I was lucky as it was way out
Post #224859 24th Nov 2013 12:11am
Googsy
Right 3rd trip to garage on Saturday car drives straight but wheel is at 2 o'clock position. On first name terms with the manager at this point. I show operator where wheel is pointing when driving straight and he sets up alignment machine. He gives me a call for me to set car into tight tolerance mode. After ten minutes he gives the thumbs up the cars ready. He asks me to take car for a drive and return if still off. I go for a drive and discover wheel is now at 1 o clock position. I go back and they tell me they are too busy and I will have to wait Censored so 4th trip back next Saturday. I'm convinced it is the steering wheel that is just out and considering removing steering wheel and moving one spline to the left at this point. Am I destined never to have a straight steering wheel Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #225241 25th Nov 2013 11:06pm
