![]() | Home > Technical (L322) > Ignition key does not turn |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
see, they all take the mickey out of me when i suggest disconnect the battery |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
One of the advantages of fitting a battery isolating switch is that when you feel the need to disconnect the battery for any reason no tools are required. Just switch on and switch off.
Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183 ![]() ![]() ![]() |
Guess what guys! Got back into the car this evening and the bl**dy key would not turn again! |
Willo98 Member Since: 20 Nov 2013 Location: Reading Posts: 14 ![]() ![]() ![]() |
Did the steering lock engages when you removed the key?
As in the ECM's will re-sync and allow you to start the engine. |
does sound like the battery might be low on voltage... ... - .- -.
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
sorry, what FF do you have?
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I had the same issue.
I will try the spare key first and if the problem remains, change the battery.
