|  | Home > Technical (L322) > Ignition key does not turn |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | see, they all take the mickey out of me when i suggest disconnect the battery   | ||
|  28th Nov 2013 2:13pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | One of the advantages of fitting a battery isolating switch is that when you feel the need to disconnect the battery for any reason no tools are required. Just switch on and switch off.
|  28th Nov 2013 2:24pm |
| Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183      | Guess what guys! Got back into the car this evening and the bl**dy key would not turn again!  | ||
|  28th Nov 2013 4:59pm |
| Willo98 Member Since: 20 Nov 2013 Location: Reading Posts: 14      | Did the steering lock engages when you removed the key?
|  28th Nov 2013 6:24pm |
| Willo98 Member Since: 20 Nov 2013 Location: Reading Posts: 14      | As in the ECM's will re-sync and allow you to start the engine. | ||
|  28th Nov 2013 6:40pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | does sound like the battery might be low on voltage... ... - .- -.
|  28th Nov 2013 7:12pm |
| goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196      | sorry, what FF do you have?
|  28th Nov 2013 10:06pm |
| Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156      | I had the same issue.
| Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183      | I will try the spare key first and if the problem remains, change the battery.
|  29th Nov 2013 6:36am |
| Posting Rules
   , the car would not run for long periods as it would just drain the battery empty in no time.
