![]() | Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade |
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
Ryan I suspect your choice is going to be pretty limited on side indicators. The size of the bulb will be one of the critical things as the space afforded to the side indicator bulb is not going to allow for some bulb types.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
i've just installed my cree amber bulbs in the rears and much joy, they are very bright and sharp like yours are Ryan...
Stan, which bulbs did you go for in the end, the 30watt or 50watt? And could you supply the link? |
i went for the 50watt ones prop mainly because of the extra cree's on the side of the bulb..
Thanks Stan.
the length is longer by about a cm but they do fit..the i only did the rears and flash rate is slightly faster..
Stan,
the wattages do seem to be confusing indeed..
Stan,
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Also just ordered 2 of these bulbs (£6.99 delivered) from the same supplier as was used to buy the main LED indicator bulbs:
@Prop, i agree with what you say and tbh and i cant see great problem having a 50w cree instead of a 21w OE bulb as according to my crees specs ,they only draw a max of 400 mA which the ranges wiring will handle . i've looked but i cant find what current the OE 21w bulbs draw which would be a interesting comparison......
‘Amber’ LED side repeaters arrived from same eBay seller as the one who supplied me with 6 x main indicator LED bulbs (2 bought as spares).
A little confused.
rear brake light is led so you cant change that, and there are 2 bulbs for the red tail and fog..
| All times are GMT |
