Home > Maintenance & Mods (L322) > Do I dilute the coolant (PDA500300)
kiter
Hoping to get the new radiator installed this weekend and my old man collected the LR coolant for me today from the stealer and he muttered something about being told that it needed diluted to 50/50 - anyone tell me if this is correct? Thanks
Post #227353 6th Dec 2013 5:09pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I topped up the coolant in my TDV8 this week and the LR supplied coolant did indeed need to be diluted 50:50 with water....but I'd still check with the dealer who supplied.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #227357 6th Dec 2013 5:35pm
Dolphinboy
you can buy a kit for £1.50 (halfords or any motor supplies shop) to test the Specific Gravity (SG) of your mix adn add accordingly.
Post #227363 6th Dec 2013 6:01pm
steptoe
If it does need to be diluted don't use tap water.
Use distilled water.
Post #227382 6th Dec 2013 6:59pm
wealy
Yep
Especially if you live in a hard water area
Post #227460 7th Dec 2013 12:32am
pld118
50/50 mix yes.
Main dealer that supplied coolant for ours said that 'tap water' is fine. I boiled a kettle of tap water, let it cool and mixed it with the coolant (they said cool boiled water was not necessary but I did it anyway).
Post #227479 7th Dec 2013 9:25am
kiter
Thanks for all the replies- just wasnt sure if the old man had got it right. Hopefully by the end of the weekend will have got the job done plus an engine oil/filter change and will give the gearbox oil a change as well. Luckily got a neighbour with a large heated garage with a ramp and every tool under the sun.......
Post #227485 7th Dec 2013 9:57am
It's important to get the mix right else you will get constant "low coolant" message's on the display (which is very annoying) Thumbs Up
Post #227486 7th Dec 2013 10:20am
tobylo
Ireland 2008 Range Rover Vogue SE TDV8 Stornoway Grey
quick tip for the distilled water: if you have one of those condensing tumble dryers, the water container in this gives FREE distilled water ! Have used this for years and no issues.
Post #230816 22nd Dec 2013 4:27pm
