![]() | Home > Maintenance & Mods (L322) > Do I dilute the coolant (PDA500300) |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I topped up the coolant in my TDV8 this week and the LR supplied coolant did indeed need to be diluted 50:50 with water....but I'd still check with the dealer who supplied.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3260 ![]() ![]() ![]() |
you can buy a kit for £1.50 (halfords or any motor supplies shop) to test the Specific Gravity (SG) of your mix adn add accordingly. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
If it does need to be diluted don't use tap water.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
50/50 mix yes.
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
Thanks for all the replies- just wasnt sure if the old man had got it right. Hopefully by the end of the weekend will have got the job done plus an engine oil/filter change and will give the gearbox oil a change as well. Luckily got a neighbour with a large heated garage with a ramp and every tool under the sun....... |
It's important to get the mix right else you will get constant "low coolant" message's on the display (which is very annoying) |
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 ![]() ![]() ![]() |
quick tip for the distilled water: if you have one of those condensing tumble dryers, the water container in this gives FREE distilled water ! Have used this for years and no issues. |
