![]() | Home > Maintenance & Mods (L322) > 2010 Facelift Questions |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
The wing-to-bumper mounting brackets are not a straightforward fit on to the earlier wings, also, I assume you have realised you need to cut the flange off the forewardmost edge also? Or fit 2006 onwards wings.....
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Many thanks for the reply paneldamage, I will try and get a pic up of the two plugs the temp sensor is there also the horns, I know about wing alteration as I have fitted a wing to replace a damaged one and the new one is facelift. I can see how the end brackets support the bumper but do they fit to the outer or inner wings ? its just a little hard to picture with the outer wings still on I will maybe get a clearer picture with wings off. Thanks Mick. |
The brackets fit on to threaded bosses on the inside face of the outer wing.... |
Hi again, well the bumper mounts explained themselves when I got a look at the back of the wings, thanks for that.
Your car had Acc Spot Lights fitted... Hence the plugs to no-where |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Maybe he had spots.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
is the second pic the temperature sensor cable or are both cables for spots.. ... - .- -.
Thanks for the replys. Aux lights would never have crossed my mind im about to look on google images as I cant picture a FF with extra lights. I think its safe to say I would never have guessed what they were for ! Stan the temp sensor is just out of view in pic. Thanks again for all replies as a new owner undertaking a facelift im sure I will be back soon,lol. |
One like this
Ahhhh Craig it makes sense now I have seen them before. There are two steel plate brackets on the crash bar bolted on with stainless bolts are these the lamp mounting brackets ? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
You will also find a couple of plugs - one each side for crash sensors - well I did anyways on my 2007 s/c when repairing it , these go into the sensors which are in the headlight support bracket.
Either the mounts for the lights or a bar... |
Thanks Craig, while your on a roll with the FF quiz I found this in the boot !! Any ideas,lol
Its the strip the bumper fits to on an early model... Bin it pal as you have replaced it with the long plastic 2009> front cross member in your picture |
