Home > Maintenance & Mods (L322) > 2010 Facelift Questions
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Hello All, As i posted in another thread i have bought a front end damaged 54 plate and I am replacing the damage parts with 2010 facelift. Today i got my headlamp support delivered and new wing mounting brackets. The headlamp/bumper bracket is straight forward but the end brackets are a little confusing, As I didnt take the car apart its a little harder to picture. Has anyone got a picture of these fitted ? Also behind the grill there are two wiring plugs hanging from the slam panel, any idea? last but not least I have offered up the 2010 front bumper and it doesnt seem too far away with my crash bar is there a specific reason to fit the later one as the 2010 fogs are below it, Sorry for the long post. Many Thanks in advance Mick.
Post #228582 12th Dec 2013 4:30pm
paneldamage
The wing-to-bumper mounting brackets are not a straightforward fit on to the earlier wings, also, I assume you have realised you need to cut the flange off the forewardmost edge also? Or fit 2006 onwards wings.....
Can't think of any plugs that hang off the slam panel? There's a big plug with 50 amp cables that runs along the bumper support - this is the connector for a winch if one is fitted. Theres another little plug that goes to an external temp sensor - this runs from the n/s headlight hole to the centre of the grille, along the bumper mount bar. The twin horns have two plugs, but are mounted on the o/s end of the bumper armature, the wires come out of the loom low down under the o/s headlight.
Post #228759 12th Dec 2013 11:54pm
mick-ne
Many thanks for the reply paneldamage, I will try and get a pic up of the two plugs the temp sensor is there also the horns, I know about wing alteration as I have fitted a wing to replace a damaged one and the new one is facelift. I can see how the end brackets support the bumper but do they fit to the outer or inner wings ? its just a little hard to picture with the outer wings still on I will maybe get a clearer picture with wings off. Thanks Mick.
Post #228984 13th Dec 2013 8:40pm
paneldamage
The brackets fit on to threaded bosses on the inside face of the outer wing....
Post #229005 13th Dec 2013 11:27pm
mick-ne
Hi again, well the bumper mounts explained themselves when I got a look at the back of the wings, thanks for that.
Here are a couple of pictures of the two wiring plugs hanging behind the grill, I hate it when your following someone else who has stripped the car before you !!
Post #229232 15th Dec 2013 12:47am
Your car had Acc Spot Lights fitted... Hence the plugs to no-where Crying or Very sad
You should have a switch inside with a pic of a light and x2 (probably under the air suspension panel) if so, that is part of the kit (turns off the facility in fog etc etc) Thumbs Up
Post #229234 15th Dec 2013 1:05am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Maybe he had spots.
Can't remember seeing them.
Post #229235 15th Dec 2013 1:07am
is the second pic the temperature sensor cable or are both cables for spots.. ... - .- -.
Post #229252 15th Dec 2013 10:14am
mick-ne
Thanks for the replys. Aux lights would never have crossed my mind im about to look on google images as I cant picture a FF with extra lights. I think its safe to say I would never have guessed what they were for ! Stan the temp sensor is just out of view in pic. Thanks again for all replies as a new owner undertaking a facelift im sure I will be back soon,lol.
Post #229255 15th Dec 2013 11:00am
One like this
http://www.wods.dk/rangerover/hi/limited/2002-rr-g4-01-400.jpg
Very rare extra to find...
Post #229259 15th Dec 2013 11:49am
mick-ne
Ahhhh Craig it makes sense now I have seen them before. There are two steel plate brackets on the crash bar bolted on with stainless bolts are these the lamp mounting brackets ?
Post #229266 15th Dec 2013 1:25pm
dingg1
You will also find a couple of plugs - one each side for crash sensors - well I did anyways on my 2007 s/c when repairing it , these go into the sensors which are in the headlight support bracket.
doh just realised they will not be on the earlier cars (I think) so don't worry if yours are missing
Post #229268 15th Dec 2013 2:01pm
Either the mounts for the lights or a bar... Thumbs Up Glad to have helped sir Bow down
Post #229269 15th Dec 2013 2:01pm
mick-ne
Thanks Craig, while your on a roll with the FF quiz I found this in the boot !! Any ideas,lol
Post #229322 15th Dec 2013 5:17pm
Its the strip the bumper fits to on an early model... Bin it pal as you have replaced it with the long plastic 2009> front cross member in your picture Thumbs Up
Post #229327 15th Dec 2013 5:33pm
