|  | Home > Maintenance & Mods (L322) > 2010 Facelift Questions |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | The wing-to-bumper mounting brackets are not a straightforward fit on to the earlier wings, also, I assume you have realised you need to cut the flange off the forewardmost edge also? Or fit 2006 onwards wings.....
|  12th Dec 2013 10:54pm |
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133      | Many thanks for the reply paneldamage, I will try and get a pic up of the two plugs the temp sensor is there also the horns, I know about wing alteration as I have fitted a wing to replace a damaged one and the new one is facelift. I can see how the end brackets support the bumper but do they fit to the outer or inner wings ? its just a little hard to picture with the outer wings still on I will maybe get a clearer picture with wings off. Thanks Mick. | ||
|  13th Dec 2013 7:40pm |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | The brackets fit on to threaded bosses on the inside face of the outer wing.... | ||
|  13th Dec 2013 10:27pm |
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133      | Hi again, well the bumper mounts explained themselves when I got a look at the back of the wings, thanks for that.
|  14th Dec 2013 11:47pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Your car had Acc Spot Lights fitted... Hence the plugs to no-where  | ||
|  15th Dec 2013 12:05am |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877    | Maybe he had spots.
|  15th Dec 2013 12:07am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | is the second pic the temperature sensor cable or are both cables for spots.. ... - .- -.
|  15th Dec 2013 9:14am |
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133      | Thanks for the replys. Aux lights would never have crossed my mind im about to look on google images as I cant picture a FF with extra lights. I think its safe to say I would never have guessed what they were for ! Stan the temp sensor is just out of view in pic. Thanks again for all replies as a new owner undertaking a facelift im sure I will be back soon,lol. | ||
|  15th Dec 2013 10:00am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | One like this
|  15th Dec 2013 10:49am |
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133      | Ahhhh Craig it makes sense now I have seen them before. There are two steel plate brackets on the crash bar bolted on with stainless bolts are these the lamp mounting brackets ? | ||
|  15th Dec 2013 12:25pm |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1422    | You will also find a couple of plugs - one each side for crash sensors - well I did anyways on my 2007 s/c when repairing it , these go into the sensors which are in the headlight support bracket.
|  15th Dec 2013 1:01pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Either the mounts for the lights or a bar...  | ||
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133      | Thanks Craig, while your on a roll with the FF quiz I found this in the boot  !! Any ideas,lol
|  15th Dec 2013 4:17pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Its the strip the bumper fits to on an early model... Bin it pal as you have replaced it with the long plastic 2009> front cross member in your picture  | ||
|  15th Dec 2013 4:33pm |
| Posting Rules
