![]() | Home > Technical (L322) > Gearbox Help needed |
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Oh dear !
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Oh dear it does look like I'm a bigger tool than the iid tool then. I really can't believe I've done this. Thanks for the input though.
Might be worth trying a software update before spending big bucks.... |
Try a software update by all means but make sure its the real thing i.e. a genuine land rover one and NOT anything less, this I cant stress enough. |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I'm sure I've read something on here about how the gearbox needs to be put into a 'learning' mode after major surgery and this allows itself to re-calibrate the settings.
Thats Great, I've found ebajema's post about the gearbox learning mode, will give it a try i doubt it will work knowing my luck, thanks for the help guys though
Oh also any idea on what a recon gearbox is going to cost?
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
We had ours rebuilt 18 months ago by TES Transmissions in Westbury, Wiltshire. It cost about £3000 but they did a fantastic job and fitted a brand new T/C.
£2-3k or recon from £1.8k |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
I've had this on a 2006 SC and I got my local stealer to re flash the software... Picked it up and it was even worse than when I dropped it off! I thought "ahh well, that's that then" spoke to the service manager who plugged it back in the following day. After waiting with baited breath! It worked |
I thought when you plugged in iid tool for the first time it made a full backup? Then if something goes pear shaped you can restore all settings back ? Present :2008 TDV8 HSE
Your right Conner it does, but it cannot put the old user data back into the adaptive memories of the engine or gearbox... Presumably it's lost into oblivion when you press "RESET"... |
Car going in Thursday guys will keep you updated.
