![]() | Home > Maintenance & Mods (L322) > noise dampening |
It's also a much quieter engine.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35692 ![]() ![]() |
the tractor sounding engine of the td6 is indeed noisy..you could stick extra sound deadening in the engine compartment but i dont think it would make much difference..
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I quite like the 6 cylinder rumble |
I don't. It's a racket - not a nice noise at all. |
td6vogue Member Since: 09 Dec 2013 Location: EDN Posts: 27 ![]() ![]() |
can the sound damper be fitted to a td6 from tdv8 |
The TD6 has an active engine mount to try to counteract some of the noise , I don't think the TDV8 even bothers.
Fit some offroad tyres and your problem with engine noise will go away instantly ... you'll be spending your days escaping the swarm of bees :lol: |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ I agree.
been in other td6's andthe same
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
I'm fitting a full Dynamat sound deadening kit in late Jan so you can wait and I'll tell you if it works.
In my early days when I had a Citroën 2cv I glued a tog 15 duvet to the underside of the bonnet |
just had oil change
