Home > Technical (L322) > Slow to restart
adigorn
Quote:
injector overflow as in ''a flooded carb'' ?
No i am referring to situation when injector/s because being faulty
allows all the fuel throughout causing massive rail pressure drop - with no start as result
Wink
moreover it can leak outside as well as inside
(the inside leak wont be detected by leak off test)
Post #231278 24th Dec 2013 2:04pm
Thumbs Up ... - .- -.
Post #231280 24th Dec 2013 2:10pm
adigorn wrote:
i understand
whats injector cleaner than in your opinion
technically approved solution
Sorry, I have no idea what you mean by that sentence, if indeed it is a sentence.
adigorn wrote:
i am just trying to say if something is faulty needs a proper repair
not pouring chemical int the tank and prayer
So what your trying to say is go for the most expensive solution first and then pray.
adigorn wrote:
if i understand correctly i am entitled to express my own opinion based on my own experiences
Try having a little respect for other peoples experiences and opinions.
Post #231297 24th Dec 2013 3:20pm
JackRegan
Not wanting to be shot down in flames here but...
If I remember rightly BMW diesels did suffer from hot start problems. I have a 320TD Tourer with the same issue although I've never bothered to get round to finding out what my exact fault is. It starts within two turns when cold yet takes 8+ when warm or hot.
I did read on BMW forums 320D and 330D in similar situations as mine and in addition to faulty fuel pumps, cam shaft sensors were also found to be blamed on occasions. Maybe worth looking into this internet wise. I am no mechanic by a long shot - but I read you can test it when hot by spraying some freezer spray on the sensor and see if it solves the problem.
Cheers
Jack 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #231301 24th Dec 2013 3:36pm
adigorn
I have a lot of respect for other people personal experiences and opinions
unfortunately have not heard many of them in this thread
No i am opting for proper diagnostics and repair
instead of wasting time for so called injector cleaners
even if its cheap its pointless
prayer is not required if you do it my way
i am sorry was not realize leak off test i am opting for is so expensive
Post #231306 24th Dec 2013 4:21pm
adigorn, we could go on like this but at the end of the day I'll leave it to you to make an ar$e of yourself. Most people contribute to the forum without being quite such an unpleasant keyboard warrior, but feel free to continue and maybe there'll be a special category in the 2013 full fat hall of fame, just for you! Smile
Post #231308 24th Dec 2013 4:36pm
adigorn
that would be something Whistle
Only joking Exclamation Exclamation
not even in a mood to fight - especially today Wink
As you said contribution is important
maybe even i with my rebel character will be able to bring something in as well Rolling with laughter
Merry Xmass Kurt Thumbs Up
Post #231309 24th Dec 2013 4:45pm
Googsy
Still reckon Gaz and Craigs row was the best over MY11.5 and MY12 dare we remember Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #231314 24th Dec 2013 6:00pm
RR1234
2014 Range Rover Autobiography SDV8 Luxor
Thanks guys for all of this - I'll feel bit more informed when I take the RR to the mechanic after New Year. When I mentioned to him he did say about checking the sensor and trying a fresh one to see if it made a difference. That not on the BMW experience is definitely worth following up as it is bound to be documented somewhere on their forum. I'll post how I get on by mid January - what a time of year to be incurring bills on my RR Confused
Happy Christmas all Smile
Post #231323 24th Dec 2013 6:46pm
JackRegan
I know the feeling, my thermostat looks to be going on the blink, that too can wait until after the festive period.
Good luck and all the best. 2024 P550e Autobiography
2005 TD6 Vogue
Post #231324 24th Dec 2013 6:49pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had the same problem a few years back on my X5.
I changed the cam shaft sensor and all was good.
Post #231329 24th Dec 2013 7:13pm
RR1234
Thanks for that advice - how much can I expect to pay for a camshaft sensor?
Post #231380 25th Dec 2013 3:44pm
RR1234
Razz I got the warm start problem sorted. Two fuel injectors needed replaced.
Post #236215 21st Jan 2014 10:08am
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Looks like someone was right Bow down Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #236349 21st Jan 2014 9:12pm
