Home > Technical (L322) > BP V TESCO Diesel
Page 2 of 6 <123456>
supershuttle
I don't want to take sides in this argument as often as not all good arguments get a bit emotive Very Happy
But I have been using TESCO fuel (Petrol and Diesel) for many. many years in a variety of motors with no problem at all, so from me at least TESCO= Thumbs Up
I used some BG244 recently and did actually convince myself of a slight improvement when it was in the fuel but alas not after. Geoff
Post #233142 6th Jan 2014 2:57am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
We had loads of problems with the BMW engine 2.0 TD4 using Sainsbury's and Morrisons mare, switched to Shell 300 miles later 90% better. I was also told that winter Diesel is even worse at the cheap stations as they do not have the winter additives in the fuel like the big players , do not know if that is true or not. Far to many gone...
Post #233152 6th Jan 2014 9:00am
As I understand it the supermarkets do not add the important additives (similar to low dose BG244) to their fuel. These additives will keep the engine internals cleaner and should really help increase the engines performance, mpg and life expectancy over the long term.
Your choice but as a dealer I never use supermarket fuel. Regular water contamination and cheaper bottom of the tank purchases are also rumoured.
You are driving a top end machine why take the chance just to save pennies. Your choice though.
Post #233157 6th Jan 2014 9:20am
tboner001
Im with you , i never put cheap fuel in any of my cars to save £1 on a tank makes no sense to me at all Far to many gone...
Post #233163 6th Jan 2014 9:59am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Always use BP ultimate.
Have had to use other fuels (like BT normal and supermarkets) on occasions and always notice the difference. The engine does not run as smooth or have as much power or torque. Obviously, thats opinion rather them imperial testing but my GF once filled it up with standard and didn't tell me and I asked her within a few hundred meters what she had put in as it felt strange.
May be mostly hype but many main dealers will recommend the premium on occasions to try and keep the injectors clean (of course you could just add red x).
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #233165 6th Jan 2014 10:14am
supershuttle
I won't get involved in the quality debate, but I need to say that I resent the suggestion I buy supermarket fuel to save a few pennies - is that not assumptive snobbery? I go to TESCO because it's the nearest by miles, I drive a diesel because I don't like going to TESCO (or any other filling station) so often.
If I wanted "to save a few pennies" I really Censored up with my car choice Very Happy
Actually I'm not really bothered at all but I've nothing better to do Very Happy Geoff
Post #233170 6th Jan 2014 10:51am
^ My meaning was that the extra spent could actually save you a lot more than pennies in the long run. I accept that Premium fuel may not be easily available to all though. Neutral
Post #233171 6th Jan 2014 11:04am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Up until retiring 3 years ago I used to cover 35000 miles a year with a new vehicle every 3 years all done on Morrisons diesel and none of my engines missed a beat. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #233172 6th Jan 2014 11:08am
My opinion is that short term your unlikely to notice anything on a new engine. It long term that the deposits build up in the injectors and other parts of the engine. The additives should help to keep these clean and other parts lubricated according to the spiel. I tend to agree.
Post #233174 6th Jan 2014 11:11am
supershuttle
Only teasing Gaz, I will actually go and get a tank of Premium fuel every now and again given the positive comments by your good self and other forum members. Thumbs Up Geoff
Post #233175 6th Jan 2014 11:12am
Post #233178 6th Jan 2014 11:31am
steptoe
It's more expensive, so it must be better. Rolling Eyes
Post #233184 6th Jan 2014 12:53pm
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
so, has anyone got opinions on wether its worth filling up with BP Ultimate or Shell V-power Nitro + Diesel rather than the standard BP or Shell stuff ?
http://www.shell.co.uk/gbr/products-servic...iesel.html
Post #233185 6th Jan 2014 12:53pm
Another vote for premium fuel. I'm another advocate of Shell Nitro+.
That said, there's a lot of Shell garages around where I live and on my route to work. I generally don't look at fuel prices as I'm not intelligent and have a lousy memory but the supermarkets are a decent and unpleasant detour for me, so any small pecuniary advantage is completely lost.
But, regardless of the above, I won't use supermarket fuel. Si. <This is my name.
Post #233186 6th Jan 2014 12:54pm
My local Shell is often cheaper than local supermarkets and this is confirmed by the fuel price app. Anyway it's not about which is cheaper it is about which is better foe the engine given a free choice.
Post #233200 6th Jan 2014 2:50pm
