![]() | Home > Maintenance & Mods (L322) > Gearbox oil change or not |
| Elena Member Since: 10 May 2012 Location: Coventry Posts: 42
My car is now booked in for the oil change |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
let us know if it drives any better after the change.. |
I will Stan, although it may be in a couple of weeks time x |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
Get a gearbox update done at the same time. It resets the adaptions and really livens up the car. |
| zetjester Member Since: 01 Apr 2013 Location: Northamptonshire Posts: 48
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
Where are the instructions that you printed off Elena? I have searched but can't find them anywhere? |
| hammiegt Member Since: 28 Sep 2013 Location: wrexham Posts: 125
I have the same quandary, mine is on 76k 2003 v8 rr, gearbox fine, don't know wether to change it or not, local autobox service center says yes, [owner runs a v8 rr] local indie says no, [owner runs a tdv6] what to do????????
| nightster1 Member Since: 26 Feb 2012 Location: Cork Posts: 14
Forgive me for resurrecting an old thread, however my experience may be of benefit to some TD6 owners. I have my engine and gearbox fluids changed every 10K miles max. The engine uses nil oil between services. The level on the engine dipstick never changes. The gearbox is now 10 years old and operates faultlessly (to date) I have 110K miles done so far on it. The oil used is Texaco 7045E. The gearbox filter is changed every 20K miles. The old filter and oil are examined in detail after draining. No evidence of glitter in oil so far. I do get a phantom 'trans fail safe mode' on the dash a few times a year, which is a bit worrying.... Current:- TD6 HSE Past:- Jeep Grand Cherokee Limited CRD x2 Jeep Cherokee Limited TD x1 |
| luckyrobp Member Since: 02 Apr 2012 Location: brigg Posts: 7
My 2002 TD6 Vogue has 161000 Miles on the clock, Going to do a gearbox flush and filter change as it makes a harsh rumble noise at low revs and high torque. I only started hearing the rumble when heavy towing but it started to appear when not towing.
| Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70
The problem is unless you have driven the vehicle from new you can't assess the state of the oil. Had mine changed this week and it was absolutely feeelthy (68k). |
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
Bringing an old thread back to life!!
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
I can’t believe the question, it’s like say the engine is running fine why change the oil.
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
I’ve decided to do a gearbox drain and top up every time I change the engine oil. It only adds around 30 minutes to the normal service time and the cost of the 6/7 litres of gearbox oil is penny’s compared to a new box.
| WB Member Since: 26 May 2016 Location: London Posts: 304
Here is the link to the ZF service method - this is very handy for the correct filling and torquing method as they differ between versions.
| All times are GMT |
