![]() | Home > Technical (L322) > Not a lot of heat in my L322 Thermostate? Hot and cold hose |
| MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 105
Anyone? Thinking about just changing the thermostat. Labour is about 150-200 pounds an hour. a thermostat is about 120, and I can change it myself. |
| jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 125
Check your pollen filter - had a similar problem when i had my RRS. Took the filter out and it was almost blocked solid. Replaced it and had a lot more heat and quicker warm up time. |
| stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341
Icecold still. Tried topping off and bleeding the system. No luck |
| rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496
Had a blocked pollen filter in my 7 series airflow 100% better now changed and I think the 7 series and early FFRT share a lot of parts/design in the engine and cooling areas There is a difference between knowing your sh!t and knowing you're sh!t
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
If the pollen filter was blocked would the car not heat up quicker inside? If there is no cold air coming in it will just recirculate the air in the cabin will it not? Could it be a FSR fault? Previously..
Its completly cold now. Not lukewarm etc. But blowing.
Heater valves were a problem on the BMW not sure if the same part on the FfRr There is a difference between knowing your sh!t and knowing you're sh!t
Waterpump? Previously..
Waterpump? Why? Isn't thermostat more likely? |
If the thermostat was stuck open it would be very slow to heat up, but it would heat up eventually. As you have no heat at all the water must not be getting to your heater matrix. A valve must be stuck or the water is not circulating is my thoughts. Previously..
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Possibly the Heater matrix valves.
Will the blower blow if the FSR is shot? |
How do i fix this? Possibel to fix so i can Get heat going back down the mountain? |
| All times are GMT |
