Home > Technical (L322) > Not a lot of heat in my L322 Thermostate? Hot and cold hose
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi!
My L322 never gets very hot in the cabin. varies if it blows hot or just lukewarm. There is plenty of coolant on it. Thermostat? Other heatervalves to look at? No apparant leaks from the expansion tank, no overheating troubles etc.
Post #236824 24th Jan 2014 2:11pm
MariusRR
Anyone? Thinking about just changing the thermostat. Labour is about 150-200 pounds an hour. a thermostat is about 120, and I can change it myself.
Post #236856 24th Jan 2014 4:56pm
jambo27
Check your pollen filter - had a similar problem when i had my RRS. Took the filter out and it was almost blocked solid. Replaced it and had a lot more heat and quicker warm up time.
Post #236890 24th Jan 2014 6:41pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
http://www.fullfatrr.com/forum/topic14965.html
Post #236907 24th Jan 2014 8:13pm
MariusRR
Icecold still. Tried topping off and bleeding the system. No luck
Post #236955 24th Jan 2014 10:39pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Had a blocked pollen filter in my 7 series airflow 100% better now changed and I think the 7 series and early FFRT share a lot of parts/design in the engine and cooling areas There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #236956 24th Jan 2014 10:40pm
If the pollen filter was blocked would the car not heat up quicker inside? If there is no cold air coming in it will just recirculate the air in the cabin will it not? Could it be a FSR fault? Previously..
Post #236958 24th Jan 2014 10:45pm
MariusRR
Its completly cold now. Not lukewarm etc. But blowing.
Checked the pollenfilter. Couldn't se anything
Post #236959 24th Jan 2014 10:50pm
rej
Heater valves were a problem on the BMW not sure if the same part on the FfRr There is a difference between knowing your sh!t and knowing you're sh!t
Post #236961 24th Jan 2014 10:56pm
Waterpump? Previously..
Post #236962 24th Jan 2014 10:59pm
MariusRR
Waterpump? Why? Isn't thermostat more likely?
Post #236966 24th Jan 2014 11:02pm
If the thermostat was stuck open it would be very slow to heat up, but it would heat up eventually. As you have no heat at all the water must not be getting to your heater matrix. A valve must be stuck or the water is not circulating is my thoughts. Previously..
Post #236967 24th Jan 2014 11:08pm
Possibly the Heater matrix valves.
Probably stuck shut. Located tucked down the right hand side of the engine, little solenoid valves will neither side heat up. There is nothing that can't be fixed with a hammer😜😜
Post #236969 24th Jan 2014 11:26pm
MariusRR
Will the blower blow if the FSR is shot?
Post #236970 24th Jan 2014 11:27pm
MariusRR
How do i fix this? Possibel to fix so i can Get heat going back down the mountain?
Post #236971 24th Jan 2014 11:33pm
