Home > Technical (L322) > Wee dash bulbs
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Wee dash bulbs
Got some spare time and the new dash pixel and ribbon so thought I would get the instrument cluster out and on the bench. Half way through the job I realise that it's not just the pixels needing replaced but most of the 5 of these wee bulbs are part of the problem.
The glass part doesn't come out. Does anyone know if you can get this from the local car spare shop or is it a LR part that needs to be ordered from say Dan.
At least I can put the cluster back together, just not back in the dash.
Post #238020 29th Jan 2014 6:59pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
That bulb looks like the 286 bulb, any auto car shop should have the bulb, they only pushed in to the housing....well they are on D1 and LC cruiser 80 I had. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #238028 29th Jan 2014 7:20pm
Shandonman
Yes, thats what I thought but they dont come apart, the filament wires are soldered to the terminals which are fixed into the plastic housing.
Post #238032 29th Jan 2014 7:53pm
Look the same as the dash light for a Ford Ka (for which you have to dismantle a good half of the dashboard to get at!) It should come as an all in one with the fitting complete... .
Post #238053 29th Jan 2014 9:23pm
Shandonman
I've found out they are used in BMW, Merc & Porsche but still no supplier this side of the pond. BMW part no is 62111391260 Will try Dan in the morning.
Post #238079 29th Jan 2014 10:32pm
Shandonman
Sorted. On their way from Dan part no is YAW000010 .
Post #238349 30th Jan 2014 11:03pm
Welshdragon
May I ask how much? If it dont work.......burn it!
Post #238359 30th Jan 2014 11:26pm
