![]() | Home > Technical (L322) > Water in spare wheel well |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Lots of thoughts & info on the Forum regarding this, Glynn . . .
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
Do not leave the rubber grommet out - mice get in! Trust me they eat holes in everything and sheet everywhere!!
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
A piece of gauze over the hole to stop the mice ?. |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Hi Glynn, im going through the same cr4p at the moment:
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Yep had the same. Changed the seal, and dry as a bone...defiantly seal. Just do it |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I had the same thing top right corner of rear window seal rubber had lifted slightly |
What is the name of the plastic bits that go in each of the four circular holes in the wheel well? Are they grommets?
One of mine was also pushed through.
Like it! Saves me searching for 'rubber to put in hole in rear' on google. Interesting results indeed. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I get water but it seems to only happen when the vehicle is parked uphill on the drive so to speak. |
Cloned earl Member Since: 28 Jan 2014 Location: Earls Colne Posts: 12 ![]() ![]() ![]() |
Same here, have taken the 'gromet' out in the bottom of the boot well, will make a seal with small rubber 'bung' with a 'drainage hole, i also removed the tailgate seal and filled the 'U' section that fits to the body with silicone, and put back onto the car, if that does not work new tailgate seal will be needed... Previous LR's
I have replaced the tailgate rubber seal now and everything seems good.
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
Glad you got it sorted Glynn, no doubt we'll be having some more rain to test the fix! I need to do mine this week, like yours it looks fine from the outside and I'm sure it'll also look like yours (knackered!) on the inside!
Oh yes !
