Home > Technical (L322) > Fanbelt/ Waterpump Issues |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Was it the pump that caused the belt to go in the first place? Ian |
6th Feb 2014 8:30pm |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 |
I hope so?? . and praying it is otherwise im lost! as i will have to replace it and run it up again. |
6th Feb 2014 10:11pm |
Any idler pulleys which may have seized. There is nothing that can't be fixed with a hammer😜😜
6th Feb 2014 10:15pm |
Changed them mate all come in the Gates Kit including the Fanbelt |
6th Feb 2014 10:23pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The water pump may spin freely if the impeller had seized and then sheared . 2008 MY Supercharged
7th Feb 2014 12:59am |
Ok Thnks for that |
7th Feb 2014 10:07am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I don't tknow the td6, but could it be that the air con clutch came in, and the compressor is seized! try turning the inner part. there is a 12mm nut I think in the middle. should turn ok with belt on, etc.
7th Feb 2014 1:12pm |
Evening Alol,
7th Feb 2014 11:17pm |
Ian |
7th Feb 2014 11:26pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Did you find out what it was after all? |
8th Feb 2014 11:03am |
