Home > Technical (L322) > Fanbelt/ Waterpump Issues
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Evening All,
My TD6 through its Fanbelt. On Going to replace it I noticed the Tensioner pulley and Guide pulleys had some play in them so I decided to change all of them with a Kit. This i did, Started her up ran fine on idle revved her up a couple of times then Bang!! Confused .On Looking in saw the fanbelt off and the Viscious fan dropped into the rad cowling Shocked The Waterpump Shaft Sheared off level with the housing,the impeller spins as free as a bird so it doesnt seem to be seized??? .The Altenator and Power steering pump spin free when spun by hand also.
Im fitting a new Waterpump and fanbelt tomorrow ,But really Worried im back to square One with this???.
Any Help will be Greatly Recieved. Thumbs Up Thankyou for taking the Time to read my Post
Post #240456 6th Feb 2014 7:48pm
T24RES
Was it the pump that caused the belt to go in the first place? Ian
Post #240468 6th Feb 2014 8:30pm
Dazzler
I hope so?? Confused . and praying it is otherwise im lost! as i will have to replace it and run it up again.
Post #240523 6th Feb 2014 10:11pm
Any idler pulleys which may have seized. There is nothing that can't be fixed with a hammer😜😜
Post #240528 6th Feb 2014 10:15pm
Dazzler
Changed them mate all come in the Gates Kit including the Fanbelt
Post #240531 6th Feb 2014 10:23pm
The water pump may spin freely if the impeller had seized and then sheared . 2008 MY Supercharged
Post #240625 7th Feb 2014 12:59am
Dazzler
Ok Thnks for that Smile
Post #240666 7th Feb 2014 10:07am
johnboyairey
I don't tknow the td6, but could it be that the air con clutch came in, and the compressor is seized! try turning the inner part. there is a 12mm nut I think in the middle. should turn ok with belt on, etc.
if its your pump, maybe your engine has just dislodged kidney stone!
Post #240751 7th Feb 2014 1:12pm
Dazzler
Evening Alol,
Rangey all done Very Happy New Waterpump fitted and new belt Running Sweet!!! Thumbs Up Thankyou for all your Help Thumbs Up
Post #240925 7th Feb 2014 11:17pm
T24RES
Thumbs Up Thumbs Up Ian
Post #240932 7th Feb 2014 11:26pm
wealy
Did you find out what it was after all?
Post #240987 8th Feb 2014 11:03am
