![]() | Home > Technical (L322) > IIDtool :) |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I've just changed the access height from the standard -40mm to -70. It's like getting into a normal car now! |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
1 - I think the IID gives the current value when changing. (Not 100% sure.) The IID does back up all values when you first plug it in. 2 - Obviously, a higher car has a higher centre of gravity. Sometimes that's a factor. I haven't played with the heights as I think JLR probably spent a lot of time and £££ getting them to what they are. Of course, some posters here have had very good reasons to change them e.g. Doing a limbo into a parking garage. 3 - Sorry, no idea. |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
^Thanks for the reply.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
Many Thanks STAN!!! |
a016738 Member Since: 10 Jul 2013 Location: Massachusetts Posts: 8 ![]() ![]() ![]() |
Here's a question...my tool only allowed me to adjust my suspension up 10mm because one of the wheels was only that far away from the max absolute value allowed by the tool. Would removing this 10mm lift and recalibrating everything according to the instructions provided by GAP reset the height values to allow for a greater lift? Seems I should haves been able to get more than 10mm out of the adjustment...especially since it was really only the one wheel with a height value that high.
pretty sure the IIDTool only allows changes of 10mm in one session, try again and see if you can go down another 10mm.. |
It was actually 13 that it would have allowed me but I kept it at 10 so I could remember how much I'd adjusted it so I could go back to the original setting. Wanted to keep it in increments of 10 so I'd remember it...so 10 was my self imposed 10mm interval max.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1401 ![]() ![]() |
dropped my settings 20mm all round in one go |
maybe i was thinking of the rsw tool.. |
drives fine - can throw it around corners a wee bit quicker
thanks, looking forward to seeing yours... |
Stan i have the standard heights! ...and 18'' Wheels.
