![]() | Home > Maintenance & Mods (L322) > Wiper Blades |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35763 ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
They thud because the angle is set wrong Stan... Exaggerated if the blades are worn out |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Can you get the "flat" style wipers for the FFRR. I have had these on my last couple of cars as both retrofit and OEM and have generally found them much better than the older style traditional blade.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Rej, No flat blades for the front of the FFRR |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Thanks, all! Much appreciated. |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Sorry to hijack.
bend the wiper arm in a bit so there's more wiper blade 'contact' with the glass.. ... - .- -.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
You will probably find that the pivot on the rear wiper arm is siezed - when I got mine, the rear wiper only cleared the centre of the screen, and when the wiper was parked, if you looked up under the spoiler you could se that the bleade was not sitting on the glass, but was about an inch proud. Turned ignition on, operated rear wiper, and turned ignition off when the blade was vertical on the window - sure enough, the arm pivot was siezed solid. |
^+1 from me too |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
sorry for the extremely daft question in advance, but I can't for the life of me work out where you measure the angle of the wiper from - i.e. what are the things marked by the red arrow in the pic below.
the red arrows point to the wiper blades looking at them from the ends..[ one has the wind flappy thing] ... - .- -.
ah that now makes sense
thats when they are parked .. ... - .- -.
thanks... |
