Home > Maintenance & Mods (L322) > Wiper Blades
stan wrote:
do you mean this bit Craig..i tried this on my td6 and just couldnt get rid of the thud, probably unlucky getting the right setting..
Yes sir Bow down Thumbs Up
Post #244936 26th Feb 2014 12:31am
Post #244942 26th Feb 2014 9:23am
They thud because the angle is set wrong Stan... Exaggerated if the blades are worn out Thumbs Up
Post #244947 26th Feb 2014 10:14am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Can you get the "flat" style wipers for the FFRR. I have had these on my last couple of cars as both retrofit and OEM and have generally found them much better than the older style traditional blade.
I also get a clunk from the rear wiper as it returns to its resting position, is this normal> If no any suggestions. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244953 26th Feb 2014 10:38am
T24RES
Rej, No flat blades for the front of the FFRR Big Cry , you can get them for the rear if you choose to.
The thud from the rear i would suggest is due to misalignment. Does it thud when returning to the park position? Ian
Post #244956 26th Feb 2014 10:46am
RR2008HSE
Thanks, all! Much appreciated. Bow down
Post #245408 28th Feb 2014 5:30am
ahebron
New Zealand
Sorry to hijack.
My rear wiper when it sweeps the window leaves 2 unwiped parts that look like someone has been pushing the car from behind. I have replaced the blade but no success.
Any ideas?
Thanks
Adrian VW Amarok 2014 Highline auto
Post #246792 7th Mar 2014 7:28am
bend the wiper arm in a bit so there's more wiper blade 'contact' with the glass.. ... - .- -.
Post #246793 7th Mar 2014 7:56am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You will probably find that the pivot on the rear wiper arm is siezed - when I got mine, the rear wiper only cleared the centre of the screen, and when the wiper was parked, if you looked up under the spoiler you could se that the bleade was not sitting on the glass, but was about an inch proud. Turned ignition on, operated rear wiper, and turned ignition off when the blade was vertical on the window - sure enough, the arm pivot was siezed solid. Big Cry
Plenty of WD 40 and manual pushing and pulling freed it off, it now sits on the screen properly and does its job. Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #246797 7th Mar 2014 8:30am
^+1 from me too Thumbs Up
Thats the usual suspect Thumbs Up
Post #246800 7th Mar 2014 9:09am
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
sorry for the extremely daft question in advance, but I can't for the life of me work out where you measure the angle of the wiper from - i.e. what are the things marked by the red arrow in the pic below.
I assume the long straight lines running diagonally are meant to be the wiper blades
thanks for the patience
 MY11 Vogue 4.4 TDV8 - "African Queen"
Post #246815 7th Mar 2014 10:50am
the red arrows point to the wiper blades looking at them from the ends..[ one has the wind flappy thing] ... - .- -.
Post #246818 7th Mar 2014 11:11am
shalz
ah that now makes sense
that's the angle when the wiper blades are at the top of the action and the two parallel lines are meant to be the bottom of the windscreen? or am I now more confused?!?!? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #246820 7th Mar 2014 11:15am
thats when they are parked .. ... - .- -.
Post #246823 7th Mar 2014 11:19am
shalz
thanks... Thumbs Up
def feeling like an idiot now... Rolling with laughter MY11 Vogue 4.4 TDV8 - "African Queen"
Post #246824 7th Mar 2014 11:21am
