Home > Technical (L322) > Adaptive Dynamics Fault light
Page 2 of 10 <12345678910>
sure Smile All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #245685 1st Mar 2014 10:12pm
adigorn
Quote:
Just a simple soldering job
unfortunately not LR approved method Whistle Laughing
Post #245703 1st Mar 2014 11:33pm
funnyguy1
United States
I spliced the wires, intertwined them, then soldered them and then used the rubber shrink wrap rubber with a hair dryer and then wrapped electrical tape. My dealer said that is exactly what they would have done. Did the same to the other side just to be on the safe side.
Post #245711 2nd Mar 2014 2:31am
adigorn
That really strange cos there is improved harness to replace the old fragile type
so would not expect a dealer to simply fix it
and...
LR do NOT recognize soldering as APPROVED method of repair Wink
(i am not saying it will not work though)
Post #245739 2nd Mar 2014 10:05am
Thanks for the advice but i don't have the correct screwdriver bit to unscrew the sh** Censored Evil or Very Mad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #245752 2nd Mar 2014 10:56am
funnyguy1
United States
My RR dealer is about a 3 hour drive from where live and are fairly new. The service manager never mentioned a replacement wiring harness but I will be sure to ask him about it. I would much rather have the dealer correct this but it was an easy fix and saved me the 7 hr round trip and a rock chip in the windscreen which has happened everytime I make the trip.
Post #245858 2nd Mar 2014 7:24pm
adigorn
do not worry connecting wires will do the job Thumbs Up
what i am saying is if you do it yourself save time and money
and connect wires but if you follow dealer path
get improved harness fitted (no risk of fault reappearing)
Post #245862 2nd Mar 2014 7:38pm
ok my local dealer fixed it in a 20 min job this morning - had a nice Latte Macchiatto too and a free car wash Razz All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #245943 3rd Mar 2014 10:35am
awclymm
Thanks to all contributors - had the same fault on my 2011 car as well. Easy fix.
Interestingly, this has happened just after I started using the access height feature more often in the last few weeks - I wonder if the increased "up and down" on the suspension has had anything to do with it? 2017 4.4 SDV8 Autobiography
Post #249202 19th Mar 2014 4:33pm
adigorn
no
Post #249230 19th Mar 2014 7:12pm
awclymm
So speaketh the oracle - would you care to elaborate? 2017 4.4 SDV8 Autobiography
Post #249231 19th Mar 2014 7:15pm
nein All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #249250 19th Mar 2014 8:36pm
awclymm
How we laughed...... 2017 4.4 SDV8 Autobiography
Post #249292 19th Mar 2014 10:02pm
cause the 2 tiny cables have nothing to do with this - they don't move - they are just factory wise not very well fitted... Rolling Eyes i was to lazy to fit this myself , so i brought my car to the dealer... All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #249323 20th Mar 2014 7:51am
Perce
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
adigorn wrote:
Its connecting two wires together so hope you can manage Wink
look for the broken wire in the area of metal covers on the top of front suspension struts (under the bonnet)
(you can undo the 2 torx and remove covers for access)
When fixed the fault will clear Thumbs Up
I had the same fault. Looked under the bonnet... cable was broken!
Scotch Lok'd it together, problem solved. many thanks Bow down Thumbs Up
Post #251777 31st Mar 2014 6:04pm
