Home > Technical (L322) > IIDtool :)
Page 6 of 8 <12345678>
mike37
Group buy.
Yes. Please let us know if this is a go-er.
Post #245536 28th Feb 2014 11:09pm
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
@Duckworth - yes would join group buy for BT version.
Post #245548 28th Feb 2014 11:53pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all
Got my IID tool from Island 4x4, no issues with delivery and activating it, they seem the cheapest. have reset my service indicator no problem, also turned off the key in ignition chime when doors are open, 2 questions if anyone can help please?
1 The setting to shut all the windows and sunroof when locking the car is activated for the remote when I hold lock the button, bur doesn't work, any ideas anyone?
2, Also I wanted to extend the time the indicators stay on for lane change, only 3 flashes at the moment, I'm unsure where to do this?
Thanks in advance for any help.
Post #245551 1st Mar 2014 12:01am
g4alan
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Hi Dan I would also be interested in a group buy for a 2005 BT version of the IID Tool.
Alan.
Post #245556 1st Mar 2014 3:06am
87RJD, 'lazy lock from the remote handset' should do that for number 1 and if you have already done that try again maybe the config didnt load up properly ,
and for number 2 afaik theres the 3 flashes for lane change and the standard full flashe ..i havnt come across a function where you can adjust the number of flashes for lane changes..
Post #245565 1st Mar 2014 7:16am
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
stan wrote:
i think that function is coming Paul, have a read here,
http://www.fullfatrr.com/forum/topic22489.html
Thanks Stan, looks like i'm in the market for one of these 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #245572 1st Mar 2014 8:43am
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
If your looking at numbers for a group buy, count me in for a B/T unit 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #245655 1st Mar 2014 7:58pm
group buy available here,
http://www.fullfatrr.com/forum/topic24031.html
Post #245952 3rd Mar 2014 12:30pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Just used my new "Tool" for the first time
Pretty easy to navigate, but when I turned the TPMS off got a bit of a shock when the engine cut, the cluster lit up then everything died for 20 seconds, rebooted and all was well....can say that I nearly messed myself when that happened.
Did / completed>
1- Chirp on alarm set / unset
2- TPMS- Off (hurrah!!)
3- Follow me home lights to 40 seconds
4- Cleared all fault codes
Wanted, but didn't succeed in doing yet....ie need help to (if possible) >>
5 -Increase indicator lane change to 5 flashes (from standard 3)
6 -Turn off lamp check (fitted LED bulbs in Fogs and comes up check fog lights every turn on now)
Anybody know if 5 / 6 can be done on a 2007 with tool updated to latest firmware? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #245981 3rd Mar 2014 3:57pm
5 you cant do, 6 should be CM [cold monitoring] and select the bulb, you might have to do HM [hot monitoring] as well..
Post #245988 3rd Mar 2014 4:52pm
paulmoran2
Which menu is that in Stan...looked in the LCM menu but couldnt see anything? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #245989 3rd Mar 2014 5:06pm
yep, in the LCM menu,
Post #245994 3rd Mar 2014 5:25pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
wish my tool had the BT option Sad
Post #246245 4th Mar 2014 4:41pm
paulmoran2
help.
Sorry if this is a daft question, but what is "Hot Monitoring" (HM) and "Cold Monitoring" (CM)....I know one of them (or both of them) checks the bulb to make sure its functioning, but could do with understanding before I play with the IID as wanting to switch off warning for front fogs as the wires are now just terminated / disconnected as the DRL switch is powering my DRL's now. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #246655 6th Mar 2014 3:36pm
cold monitoring is the ecu checking the bulb on start up, hot monitoring is when the bulb is on..switch both off for no dash errors.. ... - .- -.
Post #246661 6th Mar 2014 4:10pm
