![]() | Home > Maintenance & Mods (L322) > Fitting New Facelift air con controls to 2003 Vogue |
Nope I didn't get it sorted |
Me too |
suspension knob conversion done
Right had another look. I can get some sporadic movement and control with the auto button. I reckon once you open unit the cogs can become misaligned resulting in no action when turning the auto button. I have left it for today for fear of doing further damage. I think the only fix is a replacement panel or so I hope. The aircon works as it should in anycase so can put up with it for another while. Present :2008 TDV8 HSE
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Daveo how did you manage to convert suspension knob?you just replace it with a new type knob or converted the old one? |
hi
Thanks for your reply.Well noted |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
I switched my heater control unit over for a newer one and for a few minutes it did some strange things like flash the air con button without doing anything, but after restarting the car it seemed to work as the old one did, even with the different layout. It might be a BCU thing causing issues with the others.
Daveo just another question.If outer ring will be taken off from rear panel knob,which much cheaper to buy, will be ok sizewise for fitting it to susp knob ?(unfo donot know if front and rear knobs have the same dims)
Daveo please disregard my last question as i found in ebay the continental heating panels with quite ok prices and believe out of 5 knobs they have i will manage to safely remove at least one ring .
Daveo your lights please.
Daveo sorry for the questions but obviously i am missing something.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
looking at you 2010+ panel this is not the right panel for the upgrade, the one you are looking for is 2006-2010
Kalimera.(Good Morning)
