Home > Maintenance & Mods (L322) > Fitting New Facelift air con controls to 2003 Vogue
Page 2 of 3 <123>
Googsy
Nope I didn't get it sorted Laughing I have the exact same symptoms as you as per your video. I'm going to source a replacement as buttons are not great anyway. Seems weird auto button doesn't work like you I can only get 2 lights lit up turning knob and auto is stuck on. So like you I have just done a battery reset and issue still exists Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #250004 23rd Mar 2014 12:36pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
That's not good then Googsy Laughing I've tried two different units and the same problem remains, so I've ruled out an actual unit fault and think it's more likely an electrical issue Whistle It's one of those jobs I wish I hadn't started Mad Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #250005 23rd Mar 2014 1:01pm
Googsy
Me too Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #250012 23rd Mar 2014 2:37pm
daveo
suspension knob conversion done
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #250016 23rd Mar 2014 3:09pm
Googsy
Right had another look. I can get some sporadic movement and control with the auto button. I reckon once you open unit the cogs can become misaligned resulting in no action when turning the auto button. I have left it for today for fear of doing further damage. I think the only fix is a replacement panel or so I hope. The aircon works as it should in anycase so can put up with it for another while. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #250020 23rd Mar 2014 3:52pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Daveo how did you manage to convert suspension knob?you just replace it with a new type knob or converted the old one?
Post #431199 14th Mar 2017 6:01pm
daveo
hi
you use the chrome outer ring to go over your existing sus knob,you have to use a dermal and grind one of the arms totally off
Post #431220 14th Mar 2017 9:57pm
AKIS
Thanks for your reply.Well noted
Post #431476 17th Mar 2017 12:07pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I switched my heater control unit over for a newer one and for a few minutes it did some strange things like flash the air con button without doing anything, but after restarting the car it seemed to work as the old one did, even with the different layout. It might be a BCU thing causing issues with the others.
I will now try to hack the suspension control to add a matching chrome knob.
I also used the chrome dial covers over the sat nav controls (without the rubber inserts as I did not want to dremel the originals down) and it seems to look ok. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #431482 17th Mar 2017 12:56pm
AKIS
Daveo just another question.If outer ring will be taken off from rear panel knob,which much cheaper to buy, will be ok sizewise for fitting it to susp knob ?(unfo donot know if front and rear knobs have the same dims)
Many thanks
Post #431483 17th Mar 2017 12:56pm
AKIS
Daveo please disregard my last question as i found in ebay the continental heating panels with quite ok prices and believe out of 5 knobs they have i will manage to safely remove at least one ring .
Best regards
Post #431489 17th Mar 2017 2:12pm
AKIS
Daveo your lights please.
I bought a continental heating panel,which actually was for a newer model from ebay as was very cheap.
I took off the outer chrome rings from the knobs but the diameter of these rings is too small and under no way can be fitted to the suspension knob.
Would you please tell me for what panel do i have to look for so to find the appropriate chrome ring for the suspension knob???
Post #435274 18th Apr 2017 10:02am
AKIS
Daveo sorry for the questions but obviously i am missing something.
I have bought the heating panel as per the attached photo
Took off a chrome ring from new panel and tried to fit it over the existing black ring which rising/lowering car (yellow marked it in attached photo)but the diameter of the black ring is much thicker than the diameter of the chrome ring.
Have i actually bought wrong panel with smaller chrome rings or i donot follow the right procedure? Embarassed
Many thanks
Post #435301 18th Apr 2017 5:11pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
looking at you 2010+ panel this is not the right panel for the upgrade, the one you are looking for is 2006-2010
AKIS can you tell me if the chrome circles on your panel are metal or plastic ? and the measurements ID and OD if possible ?
Post #435328 18th Apr 2017 8:11pm
AKIS
Kalimera.(Good Morning)
You are right this is 2010+ panel but what i want to use out of it are only the three chrome rings which already taken off.(The price for this panel was extremely cheap and that's why bought it)
My intention is to fit a chrome ring on suspension knob as daveo has done but the inner diam of the chrome rings is smaller than outer diam of the existing black ring which rising/lowering car unless if i have not understood the correct way of fitting.
The rings are plastic and the inner diam must be either 27,5 or 28,5mm.
Unfo have not measured the od but if u want i can measure with accuracy both id/od during weekend,as chrome rings in summer house and rvrt to u on mon.
Post #435355 19th Apr 2017 10:01am
Page 2 of 3 <123>
