Home > In Car Electronics (L322) > Cures for black screen on reversing? |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2281 |
Well I had the same problem, couldn't find a real reason, got irritated and gave it a knock on the head, it works since....if you take out the inner plastic on top of the upper bootlid you'll see a little connector orange brownish, unplug clean, dry plug in again and it might help. |
31st Mar 2014 12:31pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
the plastic casing of the camera is in two halves. This often lets water in.
31st Mar 2014 12:59pm |
madbison Member Since: 21 Nov 2013 Location: Daventry Posts: 4 |
Thanks for the advice guys; I've had a look and it's very damp inside the casing so in the process of drying it out, using cleaner on the contacts and reassembling with the aid of a silcone sealer. Fingers crossed! |
31st Mar 2014 1:36pm |
good luck, hope that sorts it! |
31st Mar 2014 2:10pm |
