Home > Maintenance & Mods (L322) > 10 month old battery failure or something else? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
hi paul and welcome to the forum..
27th Mar 2014 4:59pm |
paulst Member Since: 19 Jan 2014 Location: United Kingdom Posts: 11 |
Thanks, will check to see if its FSR. Hopefully it will be as it looks identical procedure to my old 5 series (strange that the FSR looks identical and prob is a BMW part. but never used to drain batteries on the E39 5 series, just stop the fans working) |
27th Mar 2014 5:16pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2224 |
This may not be much use but here we go I had a similar problem with my p38 and the problem turned out to be a corroded cable from the alternator to the battery and because it was internal corrosion it wasn't obvious and also it as in the problem would move - so as the cable flexed a little good connection then poor. Before installing new cables I bobbled up from the starter to alt and alt to battery might be worth sticking a meter over the cables. Good luck anyway |
27th Mar 2014 8:07pm |
Have left the car out in the cold since considering it might be the hidden, plugged in phone charger and touch wood, it has fired up crisp and clean each time so far since disconnecting the phone charger.
28th Mar 2014 6:14am |
Interesting that when cold it has no problem thinking copper wire and cold improves conductivity a lot - - Hopefully it is cured |
28th Mar 2014 6:24am |
Sorry meant to say it sort of rules out any probs with the battery in my opinion |
28th Mar 2014 6:25am |
My wife's car. She says it has never happened when she starts it. I went to start it up this afternoon after she'd been out in it. It did it again! |
28th Mar 2014 6:18pm |
Car went into garage yday and mechanic rang me in the afternoon saying they'd found a 10amp battery drain and had also located a tracker device installed in the boot of the car (not something we've been subscribing to/ didn't even know it was there). He said those units can drain the battery and so has disconnected it, trickle charged the car and hopes the problem will be solved.
2nd Apr 2014 10:30am |
6th Apr 2014 2:58pm |
6th Apr 2014 2:59pm |
Alternator then possibly causing the issue? If its draining the battery and then not charging it when running it could cause all sorts of weirdness once running.
6th Apr 2014 4:43pm |
So the car is going back in for a third time later today re this issue.
8th Apr 2014 11:06am |
loosing power in that situation is indeed very dangerous, go and kick ass Ryan.. ... - .- -.
8th Apr 2014 11:24am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
If you look back an alternator failing on a 2007 car is a common occurrence. |
8th Apr 2014 11:28am |
