![]() | Home > Off Topic - Other Cars > FFS RANT disco roof rails. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I just HATE the quick, simple job that ends up taking half the day. I feel your pain. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8778 ![]() ![]() ![]() |
Tell me about it! There is nothing that can't be fixed with a hammer😜😜
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
I feel your pain there, seems the '5 minute' job always take all flippin day to do. |
IT issues at work come to mind. 30 minutes to print out a one page spreadsheet... |
My D4 extended roof rails were delivered yesterday morning... |
The little plastic clips are the pain, they wont pull out, it is possible to screw then out gently but more often than not they snap off, they seem to be an "improvement" over the d3 where the gutter trims are pictured as clipping in, god knows why, all bar 2 of mine snapped off. Obviously be careful drilling them out, i managed not to drill through the roof but it would be all too easy!
Mine is an HSE so already has the short rails as standard so I'm hoping this will make life much easier??? |
Possibly, they should just screw off then you will only have to take the clips out of the holes on the lower section of the roof, and then get the plastic out and bolt the front fixing on the extended rails into the exposed captive nut the rails bolt over the gutter trim. Piece of pee for a man with enough tools!
Right, tap extractor worked a treat and the offending broken tap is out, roof rails securely attached with a replacement stainless m6 button head screw,
Fitted mine today sir... `mine has plastic stoppers in the unused front holes that just flick out with your finger nail... |
Grrrrrrr, bleeding improvements. Anyhow, all done now so happy camper.
