Home > Off Topic - Other Cars > FFS RANT disco roof rails.
C Censored k
Bought some roof rails for the disco off of local stealer, fitting looked simple, three torx screws each side!
First you have to remove the rail trims, these are held on by press in plastic fixings which push into the captive nuts which hold on the rails..... Needless to say they all snapped off in the holes.
Had to then drill the plastic out and run a tap into the holes..... Which i did, however when fitting the rail on one side i hadnt run the tap into the hole enough and the set screw snapped off in the hole.... Censored so i had to drill that out and re tap the hole. Which i did.
But when i was backing out the tap it snapped off in the hole, as its a hss tap i cant drill it out Censored . I have to get a tap extractor from cromwells on monday and hope i can get it out! Otherwise im going to give it a "damn good thrashing" Censored
Censored (for good measure) ffffing things.
Rant over. There is nothing that can't be fixed with a hammer😜😜
Post #258645 10th May 2014 8:47pm
RR2008HSE
I just HATE the quick, simple job that ends up taking half the day. I feel your pain.
Post #258647 10th May 2014 8:52pm
Tell me about it! There is nothing that can't be fixed with a hammer😜😜
Post #258653 10th May 2014 9:17pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I feel your pain there, seems the '5 minute' job always take all flippin day to do. Big Cry
And we never learn either Wink All green ovals have that sick sense of humour Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #258656 10th May 2014 9:32pm
RR2008HSE
IT issues at work come to mind. 30 minutes to print out a one page spreadsheet... Whistle
Post #258665 10th May 2014 10:56pm
My D4 extended roof rails were delivered yesterday morning... Embarassed Am i in for a treat then Embarassed Censored Censored Censored Rolling Eyes
Post #258667 10th May 2014 11:03pm
The little plastic clips are the pain, they wont pull out, it is possible to screw then out gently but more often than not they snap off, they seem to be an "improvement" over the d3 where the gutter trims are pictured as clipping in, god knows why, all bar 2 of mine snapped off. Obviously be careful drilling them out, i managed not to drill through the roof but it would be all too easy!
The rails themselves arent to bad to fit i mostly put it down to may lack of the appropriate tap, then snapping the bleeding thing off. The second side went on fine, having learned the knack! There is nothing that can't be fixed with a hammer😜😜
Post #258669 10th May 2014 11:15pm
Mine is an HSE so already has the short rails as standard so I'm hoping this will make life much easier???
Post #258671 10th May 2014 11:18pm
Possibly, they should just screw off then you will only have to take the clips out of the holes on the lower section of the roof, and then get the plastic out and bolt the front fixing on the extended rails into the exposed captive nut the rails bolt over the gutter trim. Piece of pee for a man with enough tools!
Could only find one shop in derby which sells an extractor for a broken tap! And at 4pm on sat they were shut! There is nothing that can't be fixed with a hammer😜😜
Post #258672 10th May 2014 11:28pm
Post #258673 10th May 2014 11:32pm
Right, tap extractor worked a treat and the offending broken tap is out, roof rails securely attached with a replacement stainless m6 button head screw,
Easy if you have the correct kit Whistle but why they made it so difficult in the first place astounds me, if a punter bought these to fit a d4 and didnt have a box full of tools to play with then they would be knackered! There is nothing that can't be fixed with a hammer😜😜
Post #259031 12th May 2014 7:04pm
Fitted mine today sir... `mine has plastic stoppers in the unused front holes that just flick out with your finger nail... Embarassed Sorry pal, i know that doesn't help Twisted Evil But made mine a doodle to fit Whistle .....
Post #259062 12th May 2014 8:14pm
Grrrrrrr, bleeding improvements. Anyhow, all done now so happy camper.
I got a price for gen long rails and nearly fell of the chair....... The short rails werent much better at about £200. I know i was probably robbed. There is nothing that can't be fixed with a hammer😜😜
Post #259079 12th May 2014 9:23pm
