Home > Maintenance & Mods (L322) > Fuel deivery problem
kiter
Hi All
Getting really frustrated here with my FF, been good to me for last 12 months but now being a PITA. 2 weeks ago I had to be recovered - car was going fine and then complete loss of power and car ground to a halt - no warning at all. Chap who recovered me said likely to be fuel pump and/or filter. Filter changed first and then fuel pump but still no joy. Just doesnt seem to be getting any fuel at all. Checked all the fuses/relays and only thing that seems a bit odd is there is only 12v getting to pump once you start to crank the engine - I was sure in the past when I got in and turned the key to position 2 you could hear the fuel pump run for a few seconds to pressurise the system. Off to take the new pump out again as it doesnt appear to be running at all now - maybe just a duff pump - any other thoughts welcome. Ta
Post #261364 25th May 2014 1:44pm
Prop
Did you have the fuel tank pump or external fuel pump replaced?
Does the problem only occur when you have less than a third of a tank of fuel left?
Post #261371 25th May 2014 3:26pm
kiter
sorted Razz took new pump out and found the actual pump wasnt housed properly in the base of plastic unit and one of the wires had been dislodged, sorted these and re installed. Fired straight away after this. Just the FSR to sort and all will be good again......
Post #261372 25th May 2014 3:51pm
Prop
Glad you got it sorted. Thumbs Up
Post #261377 25th May 2014 5:43pm
ebajema
That is great to hear. Also read up on the 1/4 tank issue. That is now probably also taken care of in your case. Happened to me with the 4.2, luckily close to home and with support close by. Got going in no time although the waiting in the heat wasn't great. MY 2010 5.0 SC Galway green and sand interior!!
Post #261410 25th May 2014 11:34pm
mjdronfield
That's a good job done then.
Just for the thread, the petrol ff does not have the inline pump like the td6 does, as far as I can tell.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #261426 26th May 2014 7:10am
Whats strange is the 1/4 tank issue seems to effect mostly 4.2SC cars... Confused
Post #261435 26th May 2014 8:21am
ebajema
That pump sees the most work of course Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #261436 26th May 2014 8:46am
Post #261440 26th May 2014 9:42am
Glad it was an easy fix Thumbs Up
Nice to hear a success story Razz Thumbs Up
Post #261468 26th May 2014 11:56am
