Home > Maintenance & Mods (L322) > Fuel deivery problem |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Did you have the fuel tank pump or external fuel pump replaced?
25th May 2014 3:26pm |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 |
sorted took new pump out and found the actual pump wasnt housed properly in the base of plastic unit and one of the wires had been dislodged, sorted these and re installed. Fired straight away after this. Just the FSR to sort and all will be good again...... |
25th May 2014 3:51pm |
Glad you got it sorted. |
25th May 2014 5:43pm |
That is great to hear. Also read up on the 1/4 tank issue. That is now probably also taken care of in your case. Happened to me with the 4.2, luckily close to home and with support close by. Got going in no time although the waiting in the heat wasn't great. MY 2010 5.0 SC Galway green and sand interior!!
25th May 2014 11:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
That's a good job done then.
26th May 2014 7:10am |
Whats strange is the 1/4 tank issue seems to effect mostly 4.2SC cars... |
26th May 2014 8:21am |
That pump sees the most work of course MY 2010 5.0 SC Galway green and sand interior!!
26th May 2014 8:46am |
26th May 2014 9:42am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Glad it was an easy fix
26th May 2014 11:56am |
