![]() | Home > Maintenance & Mods (L322) > Fuel deivery problem |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Did you have the fuel tank pump or external fuel pump replaced?
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
sorted |
Glad you got it sorted. |
That is great to hear. Also read up on the 1/4 tank issue. That is now probably also taken care of in your case. Happened to me with the 4.2, luckily close to home and with support close by. Got going in no time although the waiting in the heat wasn't great. MY 2010 5.0 SC Galway green and sand interior!!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
That's a good job done then.
Whats strange is the 1/4 tank issue seems to effect mostly 4.2SC cars... |
That pump sees the most work of course |
Glad it was an easy fix |
