Home > Maintenance & Mods (L322) > MY11 4.4TDV8 - EGR, Decat and DPF
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Has anyone blanked the EGRs, decatted (if that's a word) and / or removed the DPF in the MY11 4.4TDV8 engine?
Thinking about getting this done to prevent future issues (rather than improve performance) and wanted to get advice, warnings or thoughts from anyone who has done them or knows about this?
I know about MOT failure but not an issue here as car will not be in the UK.
Thanks. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #261802 28th May 2014 7:57am
shalz
No one? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #262029 29th May 2014 8:01am
ebajema
Sounds like you are the first one to may try it Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #262030 29th May 2014 8:02am
shalz
I was hoping not to be... Hmmm will talk to CTC about this soon and see if I want to do it... MY11 Vogue 4.4 TDV8 - "African Queen"
Post #262031 29th May 2014 8:04am
Maybe you should talk to the companies that do the kits for other LR engines and see what they say? Discovery 4 HSE
1993 90 Tdi
Post #262033 29th May 2014 8:18am
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Hi, I have de- EGR'd my 3.0 derv when I got the car.
(4 years back)
2 months ago I decatted it.
I cant remember if anything improoved when I did the EGR hover the amount of gunk I found in the system when doing it cant be good for it.
As for the de-cat, WOW what a difference.
Imediate power gain and mpg.
I certainly recommend a de-cat.
Ther will be issues come the mot but i hope to overcome that.
Ther is a company on e- thingy that do a de-cat down pipe for about £100 for the 3.0 derv.
I am on my first long trek this morning so will report back later on results but the power gain is awsome.
Now------- my engine has done 164,000 and after reading up at length on the cats I found that the average life of them is some 100,000miles as they become blocked and less efficient.
This could well have been the case on with my engine so do read up on it.
HTH's
Bill Made in Scotland frae 'Girders'
Post #262034 29th May 2014 8:22am
shalz
Thanks for the replies.
I'll search through the threads for names but do you know any reputable companies I can enquire with? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #262047 29th May 2014 8:54am
Bofa Bill
From memory it was a company in Bridport
Have a trawl through e thingy
I will have a look later when at bvase Made in Scotland frae 'Girders'
Post #262050 29th May 2014 9:08am
Bofa Bill
Update.
Ive not brimmed it yet but sitting at 71'sh for 190miles the computer read out was 31.9.
I know the reading is not an exact science hower I have been doingnthebsamentrip for last 11 years and never has it gone above 26 on the readout.
I will be filling up tomorrow so will report back then Made in Scotland frae 'Girders'
Post #262556 1st Jun 2014 10:10am
I think new MOT may be about to check EGR's and Cats are present?
Post #262557 1st Jun 2014 10:12am
Bofa Bill
Aye thats reet Garry.
What I did.
Obtained a decat pipe and a heavy duty sleeve joint.
£10 again off e thingy
Lower the exhaust from front join and present the new de cat pipe to it.
Mark it and cut. DO NOT THROW AWAY
Fit new decat pipe to manifold, put new sleeve joint in place and slide old ehaust into it.
Tighten bolts, check for leaks and bobs yer uncle.
MOT time just replace original cat until after medical.
SORTED.
HTH's Made in Scotland frae 'Girders'
Post #262561 1st Jun 2014 10:39am
They can be present but they are unable to test if they work or not Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #263594 6th Jun 2014 10:11am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
If a vehicle left the factory with a DPF and cat then it must have one for an MOT. As has been said it is not checked whether or not there is anything inside...
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #263677 6th Jun 2014 3:13pm
Exactly my point.
As long as it looks stock they cant do anything as they have no way to test a DPF or an EGR unless they have the correct dealer diagnostics but at that point you just say no thank you and that you dont want them anywhere near the OBD port as they dont and shouldn't go near it for an MOT Smile
And not entirely true,
Older vehicles post 1992 sometimes had CAT's fitted but dont need them to pass the MOT.
Some older diesels post IIRC 2004/6 had DPF fitted but do not legally need them to pass the MOT.
Basically if there was availability that the car at that point in time had no DPF/CAT fitted then yours could be one of those vehicles and there isn't anything you need to worry about Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #263706 6th Jun 2014 7:29pm
Prop
Sounds complicated to enforce for sure.
Post #263708 6th Jun 2014 7:39pm
