![]() | Home > Maintenance & Mods (L322) > Bonnet release cable issue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Oh the joys of owning a Rangie, just when you think it's ok it bites you in the arse...
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
No it was working fine. Didn't have to use any pressure to open the bonnet, it just snapped.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
temporary bonnet release, 9th post down by 'j90',
I've ordered my second one as they are just cack. Think its the bend that causes the issue |
Kingpleb, what are they like to change, my 12year old one must be on borrowed time!!! Pete
Not too bad really. Just have some Vaseline on hand or grease to ease the rubber grommet in. Feed it they from inside the cabin and you should be ok. Make a note of the routing on the engine side to make sure it's all right when back together. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
You can significantly reduce the load on the cable by thoroughly lubricating the two bonnet catches, they are in a position where they are subject to a lot of "weather" and corrode quite badly.
Thank you both I will get SWMBO going and head off to the garage with a pot of Vaseline..... Pete
I will try to photograph the whole system when I get to it.
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
My 2007 bonnet cable snapped apprx 1 year ago, hopefully the new one will last the rest of my ownership. |
