Home > Maintenance & Mods (L322) > Bonnet release cable issue
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
went to open the bonnet this evening and the cable snapped Mad . Thankfully it has snapped where it attaches to the release handle and I can see a few strands of cable to get the pliers onto.
Can't be Censored arsed to do it tonight but once I have the bonnet up I am going to fit some kind of emergency release cables (discreetly) in case it was ever to snap where I couldn't get to it.
Can't say I am enjoying Range Rover ownership at the moment Rolling Eyes
Post #264279 9th Jun 2014 9:37pm
Oh the joys of owning a Rangie, just when you think it's ok it bites you in the arse...
Did it show any signs before letting go, get stiff etc?? Pete
-Click here for Thread-
Post #264341 10th Jun 2014 7:17am
iphs
No it was working fine. Didn't have to use any pressure to open the bonnet, it just snapped.
I will be making sure everything is well lubed when I replace it.
My old KIA Sorento is the same age as the RR and is still like a new car. No rust, everything works as it should and it never lets me down.
I never wonder if I am going to get home if I go out in the KIA, I check I have the details for recovery every time I go out in the RR. Go Figure Exclamation
British workmanship at its very best Rolling Eyes
Post #264349 10th Jun 2014 7:53am
temporary bonnet release, 9th post down by 'j90',
http://www.fullfatrr.com/forum/topic20348....nnet+cable ... - .- -.
Post #264353 10th Jun 2014 8:19am
I've ordered my second one as they are just cack. Think its the bend that causes the issue Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #264366 10th Jun 2014 9:29am
Kingpleb, what are they like to change, my 12year old one must be on borrowed time!!! Pete
Post #264377 10th Jun 2014 10:04am
Not too bad really. Just have some Vaseline on hand or grease to ease the rubber grommet in. Feed it they from inside the cabin and you should be ok. Make a note of the routing on the engine side to make sure it's all right when back together. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #264379 10th Jun 2014 10:14am
You can significantly reduce the load on the cable by thoroughly lubricating the two bonnet catches, they are in a position where they are subject to a lot of "weather" and corrode quite badly.
Have a look over the top of the black slam panel, from the engine side, and apply a lot of oil and grease to them. Thumbs Up
Post #264382 10th Jun 2014 10:39am
Thank you both I will get SWMBO going and head off to the garage with a pot of Vaseline..... Pete
Post #264383 10th Jun 2014 10:44am
iphs
I will try to photograph the whole system when I get to it.
Thanks for the replies.
Post #264482 10th Jun 2014 6:06pm
Prop
My 2007 bonnet cable snapped apprx 1 year ago, hopefully the new one will last the rest of my ownership.
Post #264486 10th Jun 2014 6:20pm
