![]() | Home > Maintenance & Mods (L322) > Brake Squeal & Removal of pads without removing calipers |
I the pads are well worn there will not be enough room to slide in the new fatter pad without pushing the piston back a bit....
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
Pins are pushed out from outside to inside.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
my 2p worth,
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
^+1 what he said...... and try not to s |
Thanks for your replies and patience |
Against all the odds... I managed the task, well the front driver's side brake pads so far (time constraints).
Well done Ryan, from small acorns and all that! |
Yer a natural! |
tuesday's top tip there ryan |
It's this pioneering spirit that made the British Empire! |
^^^ you mean holding things together with sticky tape? |
