![]() | Home > Maintenance & Mods (L322) > Brake Squeal & Removal of pads without removing calipers |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
I the pads are well worn there will not be enough room to slide in the new fatter pad without pushing the piston back a bit....
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Pins are pushed out from outside to inside.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
my 2p worth,
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
^+1 what he said...... and try not to s |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Thanks for your replies and patience |
Against all the odds... I managed the task, well the front driver's side brake pads so far (time constraints).
Well done Ryan, from small acorns and all that! |
Yer a natural! |
tuesday's top tip there ryan |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
It's this pioneering spirit that made the British Empire! |
^^^ you mean holding things together with sticky tape? |
