Home > Technical (L322) > Fancy a Full Fat with a 2.0 4 cylinder diesel engine? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
This is the new JLR Ingenium 2.0 4 cylinder engine that will be in production from next year.
9th Jul 2014 9:26pm |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 |
9th Jul 2014 9:36pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2522 |
Surely a definite for the RR Sport. Discovery Sport apparently will be launched without it as the engine plant won't be up and running in time (according to Autocar, so pinch of salt). Quite interesting engine - offset crank etc. |
9th Jul 2014 9:45pm |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 |
I can see it in a low spec SSRR.... but no chance in the full fat
9th Jul 2014 10:06pm |
Times have changed, Car magazine quoted someone from JLR saying it hadn't been ruled out. There's been a 2.1 litre, 4-cylinder diesel S Class for a few years now. |
9th Jul 2014 10:12pm |
I agree times change but the 2.1 litre is only available in the S Class as a hybrid not as an independent unit
9th Jul 2014 10:28pm |
Yes, hybrid-only now, but it wasn't in the last one. |
9th Jul 2014 10:37pm |
They reckon it'll have the output of the current 3.0 diesel, and it'll be lighter, so all this 'won't work in a big heavy car' is a bit meaningless.
9th Jul 2014 10:48pm |
I didn't say it wouldn't work.... it will absolutely work but may be as refined as the old TD6
9th Jul 2014 11:00pm |
I was in a friends 320d recently and was disappointed with the noise. And it was worse even then my ancient TD6. I think that's the biggest issue, but will be interested to see what it's really like. |
9th Jul 2014 11:10pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Well boys and girls you had better get used to it because over the next few years, small capacity -high output engines will replace ALL large capacity engines all be it with highbred as well for more performance . The world is changing and we might as well enjoy are large capacity characterful engines whilst we can . 2008 MY Supercharged
10th Jul 2014 1:57am |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
Axle is right, times are changing.
10th Jul 2014 7:35am |
To be brutally frank I was never a big lover of the 2.2d as fitted to Freelander and the poverty spec Jag XF but only because of refinement issues. It was like driving a tractor.
10th Jul 2014 8:54am |
If they'd stick an electric motor inbetween or even better let it drive a generator and use hub motors, then something very interesting can happen. Since the combustion engine is now disconnected from the drive train, it can run at optimum speed/performance for the generator to drive the hub motors and charge the battery pack.
10th Jul 2014 9:12am |
