Home > Maintenance & Mods (L322) > Front Disks / Brake Judder
Page 1 of 3 123>
mjdronfield
Having now spent 2 months using the M1 to go to work and having to had braked hard on a couple of occasions, I now have brake judder, particularly at 50 mph and above.
I intend to replace disks and pads at the front.
ECP seem to list Textar, Eicher and Pagid.
I will also ask Dan for a price.
Have you folks had the above and cured with new disks ?
Any pref on make or other ideas ?
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #272997 27th Jul 2014 6:47am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Are you sure it's not worn tyres or maybe a wheel weight missing? Might be worth a visual check first?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #273021 27th Jul 2014 11:15am
mjdronfield
Only happens when I brake.
Tyres look fine.
Need to have a good look at it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #273027 27th Jul 2014 11:41am
TheAllSeeingPie
When you brake it affects the castor angle of the wheels temporarily, which if you have only lost a tiny weight it can sometimes appear to be brake judder. It's worth just taking a quick look at the wheels and tyres to see if there's anything there that might cause it as it's cheaper than brake discs. That said it does sound like either discs or pads have gone and should probably be replaced. Hopefully they aren't too new and it's the fact they are ready to be done rather than morons on our roads that've caused this?
Post #273036 27th Jul 2014 1:37pm
whats the condition of the discs and pads? ... - .- -.
Post #273053 27th Jul 2014 2:42pm
mjdronfield
The dealer I bought it from replaced rear disks and pads when I bought it about 3 years ago. No idea how long the fronts have been on to be honest.
Only done about 12000 mls in that time though.
I don't really brake hard, but when I had to it felt like the pedal was solid, and then seemingly without me changing pressure, the front really dipped down and the pedal moved further...... I think that's the emergency brake assist. Abs never came in.
I can feel the judder through the pedal and the steering.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #273054 27th Jul 2014 2:49pm
mjdronfield
Just had a quick look, the disks seem good, no lip on one side and only a slight lip on the other.
Brake dust shields are both loose though.
Didnt take wheels off, as its too piggin warm for that malarky.......
If all it takes to Censored the disks up is a bit of hard braking, how is everyone else managing ? Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #273079 27th Jul 2014 4:32pm
TheAllSeeingPie
Given the large amounts of brake dust I regularly remove from my wheels I reckon you've just been unfortunate. Maybe new pads will sort it?
Post #273152 27th Jul 2014 10:14pm
mjdronfield
I still have said judder, and am deciding whether to let garage do it or go diy.
I don't want britpart or to pay extra for the green oval on the box.
I've seen these,
What do you all think ?
http://www.ebay.co.uk/itm/Land-Rover-Range...4623f7b4db
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #283366 28th Sep 2014 5:49pm
i'd have a word with steve at AF, he does some great brembo deals,
http://www.advancedfactors.co.uk/ or pm via the forum. ... - .- -.
Post #283367 28th Sep 2014 5:54pm
mjdronfield
Many thanks Stan.
Note to self - Must remember - Site Sponsors, Site Sponsors.........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #283368 28th Sep 2014 6:02pm
Should be good. But give dan a ring as the lr branded brembo discs for the tdv8 were only £50+vat a side last year. Poss less for the td6
Have a look at LRdirect as well our guys on here for parts, seem quite reasonable and usually have a decent selection, from LR branded kit to oem and down to britpArt. Though some britpart stuff is oem as they do their own stuff(the stuff known as Censored part) as well as oem stuff from Delphi etc.
I would have a go at the discs yourself it's pretty simple if you are careful, just need to be mindful of the pad sensor.
I would check for binding calipers too if you have a lip one side and not the other, they are trw calipers after all.......
Check the relative thickness of the pAds as well as the usual heat test, as one thinner pad could point to a problem. There is nothing that can't be fixed with a hammer😜😜
Post #283369 28th Sep 2014 6:02pm
mjdronfield
Thanks, will do.
Will obtain more prices tomorrow when the "shops are open".
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #283371 28th Sep 2014 6:13pm
miggit
Hi ya Bud! I have just spent the weekend swopping discs around on the Hang Over, Censored part drilled slotted and warped, but thats another link!
Anyway my good bud next door, who is vauxhall trained and now working for the post office, told me to give the area around the locking screw a dam good thrashing. I couldn't find a whip, so I bashed the stuffing out of it with hammer of Thor! Better known as a copper and hide mallet, ex MGB wire wheel spanner.
The net result was the disc retaining screw, that everyone else seems to strip then drill and bash with screwdrivers and chisels, came out with no fuss, using a 6mm allen bit driver for the socket set. Sometimes bashing the cr*p out of things does more than make you feel better Cool Yesterday I couldn't spell Engineer... Today I are one!
Post #283391 28th Sep 2014 8:09pm
mjdronfield
Thanks for the advice.
I've just ordered the Brembo kit from our illustrious site sponsors Advanced Factors.
The kit has the disks and pads, and some copper grease and thread lock.
Now, I see the inter web has thoughts about not greasing anything as it can't handle high temps well and goes thin and runs..... Is this true ? I will prob apply it to back and edges of pads anyway.
And also, I'd imagine one would put a bit on the sliders for the caliper, but RAVE says clearly DO NOT LUBRICATE. Is that right ?
I will also purchase some spray brake cleaner from Halfrauds as I understand the new disks will need a good clean before fitting......
As you can tell, I'm not a brake expert...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #283586 29th Sep 2014 4:20pm
Page 1 of 3 123>
