Home > Technical (L322) > 2003 FFRR TD6 - Message
davemfox
Hi,
When I turn the ignition on the following message appears - "HDC Inactive" - anyone know what this is??
Thanks,
Dave 1993 YZF 750 SP
Post #27476 8th Sep 2010 11:51am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Sad You have a problem with your Air Suspension .
I also understand that this is one message that can be thrown up if you have low battery voltage.
Post #27478 8th Sep 2010 12:29pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
From the handbook.
"HDC INACTIVE A fault in the Hill Descent Control
system has occurred.
Do not attempt the planned
descent/ascent and consult your
retailer at the earliest opportunity."
You could try switching the HDC off and on again.
Ian
Post #27480 8th Sep 2010 12:39pm
delamo
Ref - IanV8's reply...
Embarassed Oops! - sorry dave, I could be wrong?
I thought the HDC and Air Suspension were connected in some way?
If the HDC Inactive message pops up, doesn't this automatically drop the suspension height?
Edit davemfox - have a look at this earlier fullfatrr.com thread about the same thing...
http://www.fullfatrr.com/forum/post7636.html
Post #27482 8th Sep 2010 1:04pm
JW911
In theory, you have a problem with your suspension. In practice, you almost certainly have a problem with your battery, ie. it's on it's last legs. My 4.4V8 started doing this and six months later I had to replace the (original!) battery. Never had the problem since.
What appears to happen is that there isn't enough power in a low battery to self-test all the systems before the engine starts, hence the warning which immediately clears as soon as sufficient power is supplied.
Edit: Just noticed that's my thread highlighted above! 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #27498 8th Sep 2010 3:13pm
davemfox
IanV8 wrote:
From the handbook.
Ian
this worked Thumbs Up Must have been lack of use.
I'll bear the battery aspect in mind JW911 Thumbs Up
Post #27501 8th Sep 2010 3:22pm
daveo
hi i get this some times, not that oftern but i think its one of them gremlings, did it go when you switched it off and then on, if so dont worry my mate gets it at least once a week and he never had a prob with his car. V8 facelift Range Rover Autobiography 22" wheels.
Post #27506 8th Sep 2010 4:29pm
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
HDC Inactive would display when switch is activated to show it is not working - if it comes up when ignition starts, part of system checks, then disappears then I would say 'JW911' is correct, and low volatge is causing the phantom warning. Worth checking battery leads are tight!
Mine displayed this on starting for over a year until battery finaly died - once Varta battery is replaced with another Varta - fault has never came up since.
HDC has never failed and has remained functioning throughout.
Air suspension faults would come up on their own if there is a fault but would not always sink to lowest setting - thankfully.
Post #27513 8th Sep 2010 6:06pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Mine comes up regular, Recent OE spec Battery. The message disappears in seconds and no Arrows to show a persistant fault. HDC works fine to.
Its just personality of the car.
When I wake up first thing I probably have similar issues, especially if its for an early turn 5.30am Exclamation 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #27606 9th Sep 2010 3:41pm
davemfox
Cheers for your help gents Smile
It only came up once the engine was running and I was playing with the buttons
Now just got to sort out the non-working mirror fold issue...
Post #27713 10th Sep 2010 11:06am
