![]() | Home > Technical (L322) > 2003 FFRR TD6 - Message |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 ![]() ![]() |
Hi,
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
From the handbook.
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Ref - IanV8's reply... ![]() I thought the HDC and Air Suspension were connected in some way? If the HDC Inactive message pops up, doesn't this automatically drop the suspension height? Edit davemfox - have a look at this earlier fullfatrr.com thread about the same thing... http://www.fullfatrr.com/forum/post7636.html |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 261 ![]() ![]() |
In theory, you have a problem with your suspension. In practice, you almost certainly have a problem with your battery, ie. it's on it's last legs. My 4.4V8 started doing this and six months later I had to replace the (original!) battery. Never had the problem since.
this worked ![]() I'll bear the battery aspect in mind JW911 ![]() Dave 1993 YZF 750 SP |
hi i get this some times, not that oftern but i think its one of them gremlings, did it go when you switched it off and then on, if so dont worry my mate gets it at least once a week and he never had a prob with his car. V8 facelift Range Rover Autobiography 22" wheels.
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 ![]() ![]() ![]() |
HDC Inactive would display when switch is activated to show it is not working - if it comes up when ignition starts, part of system checks, then disappears then I would say 'JW911' is correct, and low volatge is causing the phantom warning. Worth checking battery leads are tight!
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Mine comes up regular, Recent OE spec Battery. The message disappears in seconds and no Arrows to show a persistant fault. HDC works fine to.
Cheers for your help gents |
