![]() | Home > Technical (L322) > 3.6 TDV8 EGR options? |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
They can be mapped out, with the appropriate software |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
Yup, I got a Viezu v-box for my s class and they mapped out the egr. You get two maps and a code reader for £400ish |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Sounds quite steep!
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
I looked into this and was told that the EGR valves definitely couldn't be blocked? |
| Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190
Have a chat with gary @ Alive Tuning - he's managed to map them shut ... Regards,
Would love to know how these sprays repair these little roller bearings
Nick, bite the bullet and get them done before you overspeed one of your Turbo's! This will usually result in the Turbo failing very soon after the EGR is replaced, often destroying your engine! This is fact sir!!! |
| goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196
craig, if the EGR is blanked out or mapped out will it be detrimental to the turbo?
| NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92
Hi Craig,
Would love to hear the theory behind this too... |
The EGR allows a small amount if exhaust gas into the engine under certain circumstances. This is usually when the engine is hot and not under significant load. The added exhaust gas essentially reduces the effective amount of oxygen, which in turn can be thought of making a 3.6 into a 1.6 temporarily. This is good for emissions too as having the exhaust gas become part of the combustion again reduces Nox emissions. Disabling the EGR has no detriment to the engine as it's an emissions device and isn't used 100% of the time.
You can't block them as the ECU will still attempt to activate them. Instead removing the duty cycle from the ECU and it'll never attempt to monitor or open and close it.
07 Supercharged - Still breaking her in! Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html 18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html |
| Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192
Craig is speaking from experience there ..... just happened to mine which Craig has been fixing my broken engine .... Stephen Gazard Range Rover L405 LWB SVA Overfinch / Bespoke Maserati GT 2017 Maserati Levante Trofeo Mercedes SL63 AMG Mercedes S500L |
i had no idea re.the full function of the EGR.
| All times are GMT |
'Bertha' - 2014 SDV8 Autobigraphy
