Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown
Page 3 of 9 <123456789>
wealy
This is a real mystery.
My shift motor end cap. The deep drawn pressing seems to have a slight plit in the end and seems to be weeping? Im guessing the cap cannot be bought alone?
Post #262464 31st May 2014 3:40pm
No the whole motor has to be replaced. Good to narrow it down though. Is it possible it is coming from the seal with the box and tracking along? There is nothing that can't be fixed with a hammer😜😜
Post #262480 31st May 2014 5:02pm
wealy
This really is a mystery - it sounds daft but it seems to be coming from the cable sheathing that comes down from the engine bay? Anyone have a diagram of where this comes from / goes to?
Post #262793 2nd Jun 2014 4:44pm
Is it possibly leaking out of one of the commectors the cables run into and tracking back up the sheath? Not sure where the other end goes, would hazzard a guess at the electronics box under the bonnet.
Are you sure its tfr box oil you are seeing, its a yellowish lube.
I had a look at mine and all seems to be well now, no additional oil around the bottom of the box! Looks like a result. There is nothing that can't be fixed with a hammer😜😜
Post #262798 2nd Jun 2014 5:35pm
wealy
Well the plot thickens.......
Where the flange is for the rear prop, there seems to be a trail of oil getting to the flange and spinning off and hitting the cage and the sound proof material and then dripping to the floor. But - for the life of me I cant see where its coming from. There is no trace whatsoever from anywhere near the flange???
Post #264384 10th Jun 2014 10:47am
wealy
Post #278471 1st Sep 2014 2:41pm
Is it possibly coming from the shaft seals on either the gearbox or trans box. Splitting the transfer box is permitted to change these so may be a point of failure on the tfr box. There is nothing that can't be fixed with a hammer😜😜
Post #278487 1st Sep 2014 4:15pm
RRPhil
I'll still have the casings from the teardown lying around in the garage somewhere. I could dig them out if they'd be any use to you.
Phil
Post #278519 1st Sep 2014 7:57pm
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Wow. Phil's Knowledge, Skill and time he puts into these teardowns is amazing. The difference between theory and reality is that in theory it will work.
Post #278564 2nd Sep 2014 6:29am
wealy
If you could dig them out Phil that would be great. You can't get them from Landrover.
Post #278571 2nd Sep 2014 8:26am
RRPhil
Managed to find the casings, and they seem to be in good condition. I never finished completely stripping the rear case so there are a few bits still in there.
Anyway, yours for £30 if you want them wealy?
Phil
Post #278734 2nd Sep 2014 11:29pm
wealy
Casings
Great
I will have them
Cheers phil
Post #278750 3rd Sep 2014 6:50am
wealy
My car is a my 2010 (built in 2009) they will fit ?
Post #278751 3rd Sep 2014 6:51am
RRPhil
I’ve got casting numbers of 845 422 7091 (front case) and 845 422 8031 (rear case) on mine. Unfortunately, because I bought the transfer case assembly on its own (eBay), I don’t know what model year vehicle it came from.
Phil
Post #278905 3rd Sep 2014 7:49pm
wealy
PM sent
Post #279869 9th Sep 2014 8:53am
