Home > In Car Electronics (L322) > Blank Screen |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7651 |
When I swapped my TV unit for a hybrid one, I got a green type display when the connection wasn't good, so I'd imagine you have a good connection, but no power up.
4th Sep 2014 5:32pm |
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 36 |
Yeah, I think running around with the satnav unplugged may have upset it, might pull the battery leads off for a bit and see if that tricks it back to life.
4th Sep 2014 5:35pm |
I've just put BMW blank screen into google, as it's the same system, as you know, and they seem to say disconnect battery to reset it or it's a faulty nav unit, as that processes the video.
4th Sep 2014 5:43pm |
Is this any use ?
4th Sep 2014 5:47pm |
I tried pulling fuse 49 for 1/2 an hour. I'll try pulling the battery tomorrow.
4th Sep 2014 9:09pm |
I've not tried with the unit unplugged, but I believe the nav sends the video to the front end, so I'd imagine it won't work without the nav.
4th Sep 2014 9:15pm |
Everything worked apart from the screen and the nav of course.. |
4th Sep 2014 9:19pm |
Do you get the red light on the nav unit ? In the boot ? 2011 Range Rover Vogue SE 4.4 TDV8
4th Sep 2014 9:23pm |
Yes, the red light comes on and you can hear the disc spinning away, so that seems ok.
4th Sep 2014 9:46pm |
Mine has the standard v32 software loaded, I understand some modded ones with speed cameras and 7 digit postcodes can cause issues.
4th Sep 2014 9:52pm |
Have to admit, it's got me a bit baffled, I really did expect it would burst back into life when I plugged the original unit back in. There is a link on that site describing how reloading the firmware managed to recover the system.
4th Sep 2014 10:01pm |
Get it working with the old mk3 unit if you still have it. That's a known working unit.
4th Sep 2014 11:03pm |
OK, so I tried the software update on the new unit after having unplugged the battery for 20 minutes, no joy.
5th Sep 2014 1:25pm |
A step in the right direction is always good.
5th Sep 2014 4:59pm |
