![]() | Home > In Car Electronics (L322) > Blank Screen |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
When I swapped my TV unit for a hybrid one, I got a green type display when the connection wasn't good, so I'd imagine you have a good connection, but no power up.
| Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37
Yeah, I think running around with the satnav unplugged may have upset it, might pull the battery leads off for a bit and see if that tricks it back to life.
I've just put BMW blank screen into google, as it's the same system, as you know, and they seem to say disconnect battery to reset it or it's a faulty nav unit, as that processes the video.
Is this any use ?
I tried pulling fuse 49 for 1/2 an hour. I'll try pulling the battery tomorrow.
I've not tried with the unit unplugged, but I believe the nav sends the video to the front end, so I'd imagine it won't work without the nav.
Everything worked apart from the screen and the nav of course.. |
Do you get the red light on the nav unit ? In the boot ? 2011 Range Rover Vogue SE 4.4 TDV8
Yes, the red light comes on and you can hear the disc spinning away, so that seems ok.
Mine has the standard v32 software loaded, I understand some modded ones with speed cameras and 7 digit postcodes can cause issues.
Have to admit, it's got me a bit baffled, I really did expect it would burst back into life when I plugged the original unit back in. There is a link on that site describing how reloading the firmware managed to recover the system.
Get it working with the old mk3 unit if you still have it. That's a known working unit.
OK, so I tried the software update on the new unit after having unplugged the battery for 20 minutes, no joy.
A step in the right direction is always good.
| All times are GMT |
