Home > Technical (L322) > L322 gaff (plea for help) &weirdness (plea for explanati
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
a) erm... took the passenger seat out for something yesterday, and the airbag light won't go out... Got a BMW lead and an OBD2 lead - is there any free software I can use to reset it? I tried disconnecting the battery for 15 minutes to see if it would reset, but it didn't
That leads on to part b)
When I reconnected the battery after 15 minutes I didn't have to re-enter the radio code! Why? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #280588 12th Sep 2014 6:18pm
(a) don't know
(b) there is no radio code so don't go looking for one . 2008 MY Supercharged
Post #280669 13th Sep 2014 2:00am
a) navcoder.....use forum search
b) dont need a code ... - .- -.
Post #280676 13th Sep 2014 7:32am
The light has come on because of the seatbelt pre tensioner being unplugged (when you disconnected the harness from the seat) for anyone else doing this job at home... Disconnect the battery first then ONLY reconnect it when the seat harness is reattached Thumbs Up
I know that won't assist you THIS TIME sir but may help others reading this thread... Thumbs Up
Post #280718 13th Sep 2014 12:37pm
mjdronfield
I had to register navcoder to get it to do anything but read things.
Could have changed now though, as that was over 2 years ago.......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #280733 13th Sep 2014 2:32pm
Navcoder still needs to be registered & paid for. ( I know 'cos I had to move it to another laptop, and Jochen is still keeping a tight rein on things, even though he did my transfer for free!)
@tymh
If you shell out for an OBDII bluetooth reader and have an android phone you could try "Torque Pro". Not sure if it will handle all LR specific fault codes though.
Maybe you have someone with All Comms in your area who can help? .
Post #280743 13th Sep 2014 4:57pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Hawkeye resets airbag warning lamps
Post #280745 13th Sep 2014 5:11pm
tymh
Noted! Very Happy Tym
Post #280894 14th Sep 2014 1:03pm
tymh
b) dont need a code
I *thought* navcoder, as I have that, but couldn't find it in there. Will search forum for it before I go any further Wink Tym
Post #280895 14th Sep 2014 1:04pm
tymh
Sorted my NavCoder problem and the airbag light is now reset Thumbs Up Tym
Post #284540 5th Oct 2014 9:33pm
Care to share solution ? .
Post #284553 5th Oct 2014 10:43pm
tymh
Sorry Joe... I used the singe module code reset on the AB module to clear the fault codes Tym
Post #284555 5th Oct 2014 10:48pm
jaybear
France
can it be done via IIDTool
Just a question .
can the reset of the airbag light be done with the IID Toll ?? and if so how ??
thanks for your input if anyone knows . Very Happy Very Happy Very Happy Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #284587 6th Oct 2014 9:31am
tymh
NavCoder is only 20 Euros if the IID won't work. Tym
Post #284588 6th Oct 2014 9:33am
@jaybear, the iidtool can clear an airbag error... ... - .- -.
Post #284589 6th Oct 2014 9:47am
