![]() | Home > Technical (L322) > Britpart drilled/slotted disc's DA4609 have you got? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi is putting your finger in the groove at the top or the bottom of the disc, at the moment the inner part of the groove hits the underside of the pad first, this should have the effect of flinging any dust away from the centre of the disc. Which by the way is the wrong way according to what I found on the web, but that is for ones with directional vents in the disc.
UPDATE!!!!!!!!!!!!!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Just because they drill holes in them and grind slots doesn't mean they are any stronger or better than OE discs, in fact drilling holes in them weakens the disc, I've had several performance cars in the past that came with drilled discs, they have all cracked around the holes, due to creating an uneven heat dispersal by drilling holes, if you want to update the brakes just change the pads, modern silicon based ones are good and they produce less dust as well.... Pete
The main reason for changing them is 1, the old discs are so worn you could use them to make a paddling pool! And 2, because of the amount of different trailers that I tow, it is impossible to guarantee that the brakes are 100%. So rather ending up in a ditch with smoking brakes, I'd rather put up with the greater wear. The last 2 cars that I used for type of work both suffered from major brake fade, admittedly they were Landcruisers, but I'd rather err on the side of caution and not have to carry spare under pants in my tool kit |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
whilst bedding in your new brakes, use the sticker supplied in the box.....
Oh, I didn't get that part of the |
Yes thats the way mine go, however a word of caution bud,
you can get arrested for putting your finger into the groove in public ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Update!!!!!!!!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Is a result, I hope that the new ones are better! There is nothing that can't be fixed with a hammer😜😜
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Not just Britparts I got some from Advanced Factors earlier this year and after just 3,000 miles they are warped as hell and completely fin barred. Not going to waste good money sending them back ( imagine the postage costs ! ) . Now need to find another set for the front. |
I got mine from mode land rover, helpfull chaps! Yesterday I couldn't spell Engineer... Today I are one!
Drilled and Slotted Disc The Final Chapter, Please!
Well that's a result.... Do I hear some garage wall art going on with the knackered one?? Pete
Its a nice idea, but Mode L/R want the old ones back, presumably they want them to throw at the Britpart rep. when he come-a-knocking |
