Home > Technical (L322) > Pre heat |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Ah I was sitting in the cab or at the front end so didn't listen for any ticking......there was no smoke at all ( I presume you mean from the burner under the battery?) |
6th Oct 2014 7:42pm |
I'm also informed by the chap at Webasto that my remote as per my previous photo is a T80? Not as I thought a T90/91.... |
6th Oct 2014 7:44pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
yep, or its exhuast Cheers James |
6th Oct 2014 8:39pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
read this a few times to get your head round it
7th Oct 2014 9:46pm |
Thanks for that, although it a bit above my head it's a great write up
8th Oct 2014 4:19pm |
milesg Member Since: 18 Dec 2013 Location: Gloucestershire Posts: 120 |
Guys I have read the brochure etc but....I got a new battery fitted to my remote, seems synced, press on and it goes green solid for 3 secs then flashes green every 2 secs, fan under the bonnet trim starts up, hit off and it turns off. T91 remote on a 2010 tdv8 car.
8th Oct 2014 10:16pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
M...does the system operate correctly when using the touch screen rather than the remote? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
9th Oct 2014 8:20am |
Ill check this evening mate. Weird it will vent but not heat. I'll revert asap. Thanks again
9th Oct 2014 12:32pm |
A local LR dealer told me today that the FBH does not works unless temperature is below 6 degrees (not 16 as I believed) can anyone confirm this ? |
9th Oct 2014 5:40pm |
Manual states below 16'c it will heat and above 16'c it will cool. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
9th Oct 2014 5:52pm |
if you manually turn it on it will heat at current outside temps. Cheers
9th Oct 2014 7:46pm |
It's a temperamental thing.....
9th Oct 2014 8:46pm |
That's what I thought Paul.....but LR tech says 6'c ? |
10th Oct 2014 2:13am |
I can't hear any 'ticking' at all ? |
10th Oct 2014 2:18am |
